Running 1/2 inch fuel line #2431806
01/09/18 08:43 PM
01/09/18 08:43 PM
Wausau Wi
Convertcuda Offline OP
Wausau Wi
I need to run 1/2 fuel line on 70 ebody. I know how to make the fuel line all the back except where it goes around passenger side leaf spring hanger. There are many 90 degrees bends right there. I want to match factory as much as I can. Has anyone did this process where it looks professional. Any help or ideas. Money is not the object but how to get it look nice and function. Maybe someone has done this in a different way that I'm not aware of. Want to avoid being close to exhaust system.
Thanks Ken
Re: Running 1/2 inch fuel line [Re: Convertcuda] #2431845
01/09/18 09:55 PM
01/09/18 09:55 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I'm guessing you want to keep it somewhat stock looking, but I run mine with braided steel and AN fittings. MUCH easier to deal with.
Brian
Re: Running 1/2 inch fuel line [Re: '72CudaRacer] #2431855
01/09/18 10:09 PM
01/09/18 10:09 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
This is 5/8
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Running 1/2 inch fuel line [Re: Convertcuda] #2431912
01/09/18 11:15 PM
01/09/18 11:15 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Did this with my 70 Challenger I will try to take of pic of mine tomorrow. Pretty sure it was not needed in my case should of just did 3/8.
Re: Running 1/2 inch fuel line [Re: RTSE4ME] #2431922
01/09/18 11:29 PM
01/09/18 11:29 PM
Wausau Wi
Wausau Wi
Yes sounds good keep the ideas and pictures coming. I plan to use those special AN fittings. How far away do the fuel lines need to be away from the exhaust? Mine does not have to look stock but I want it to look like it was made that way.
Ken
Re: Running 1/2 inch fuel line [Re: RTSE4ME] #2431923
01/09/18 11:31 PM
01/09/18 11:31 PM
Wausau Wi
Wausau Wi
Yes, take your time but nice clean shots would be awesome. Here's my phone if you want to text them to me 715-432-5080
Ken
Re: Running 1/2 inch fuel line [Re: Convertcuda] #2432006
01/10/18 01:16 AM
01/10/18 01:16 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Finelines bent me up a 1/2" line to fit in the stock location on my '73 A-body. Not the greatest thing to install but it looks and fits like original. I would imagine that they could do you one???
Re: Running 1/2 inch fuel line [Re: Convertcuda] #2432057
01/10/18 03:28 AM
01/10/18 03:28 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I installed 1/2” hardline on my car last year. I just kept it inside the frame rail and subframe connector all the way forward, pretty much a straight shot. Originally I wanted to follow the stock line location, but it just made more sense to me to go in a straight line.
Re: Running 1/2 inch fuel line [Re: StealthWedge67] #2432097
01/10/18 10:33 AM
01/10/18 10:33 AM
Wausau Wi
Wausau Wi
Did you have any issues with exhaust temps heating the fuel? Any pics would be great.
Thanks Ken
Re: Running 1/2 inch fuel line [Re: Convertcuda] #2432174
01/10/18 01:51 PM
01/10/18 01:51 PM
polyspheric Offline
polyspheric  Offline
Just my 2¢?
Braid + AN are overkill w/r/t pressure - there isn't any to speak of (compared to brake lines, oil filter/cooler, power steering, even ATF cooler).
Difficult to assemble on a bench (keep Band-Aids and peroxide handy), impossible to repair under the car.
Steel lines will last 30 years if you keep them dry.
Never above, several inches lateral or you'll vapor lock.
Boffin Emeritus
Re: Running 1/2 inch fuel line [Re: Convertcuda] #2432202
01/10/18 02:41 PM
01/10/18 02:41 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've run 1/2" aluminum hard line on several Mopars in the last 30 years; generally following the OEM routing except for frame-connector cars, which get a straighter shot. Key is adequate clamps & using hoses at each end (tank & pump or pumps). I use fire-sleeve anywhere near a heat source. For street use I prefer to run the fire-sleeve the full length of the line so it's really protected & insulated.
I figure anything with 1/2" line is no longer strictly restored, and at that point function is more important than exact originality.
Re: Running 1/2 inch fuel line [Re: Convertcuda] #2432208
01/10/18 02:47 PM
01/10/18 02:47 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I ran -8 feed and return in the cloth braided hoses when I changed to EFI. That stuff is so much easier to work with than the steel braided it is ridiculous.
68 Barracuda Formula S 340
Re: Running 1/2 inch fuel line [Re: Bad340fish] #2432475
01/10/18 10:03 PM
01/10/18 10:03 PM
Wausau Wi
Wausau Wi
Thanks for info guys. Yes fuel line does not have to look original and has to function. I was looking for anyone who did this so it looks like it was made to be there "like a new car" I got some nice pictures from one person but always looking for more ideas. I have customer that wants me to make look super clean and nice. Money is no object.
Thanks Ken 715-432-5080
Re: Running 1/2 inch fuel line [Re: Bad340fish] #2432589
01/11/18 01:01 AM
01/11/18 01:01 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That's what I used, black -8an braided, extremely easy to work with.
Re: Running 1/2 inch fuel line [Re: Convertcuda] #2432608
01/11/18 01:42 AM
01/11/18 01:42 AM
Puyallup, WA
Puyallup, WA
Thanks Ken
I have not had any issues with fuel temps that I’m aware of. It is on the inside of the frame rail as it enters the engine bay towards the mechanical pump. That’s where it’s closest to the headers, I can’t really tell you right now how close it is because my engine is currently torn apart and the headers are out. I don’t remember being concerned about it when I routed it though. shruggy
At the rear, my picture would look nearly identical to whitedarts above.
Re: Running 1/2 inch fuel line [Re: WHITEDART] #2432738
01/11/18 10:56 AM
01/11/18 10:56 AM
Canada
onig Offline
onig  Offline
Canada
Originally Posted By WHITEDART
This is 5/8
What are the two other lines for? Is there a cooler setup in the rear.
69 Dart
