Re: 65 fury radiator options
[Re: 65fury]
#2430847
01/08/18 12:24 AM
01/08/18 12:24 AM
I'd suggest a Champion 3 row core with a shroud & a properly spaced fan with the most blades & ~ 1.33 overdriven pulley ratio & a high flow 180 or 185-190 stat. I'm assuming A/F ratio and timing especially idle/low speed timing is adequate.
[Re: 65fury]
#2430854
01/08/18 12:46 AM
01/08/18 12:46 AM
I got one for a 65 dart & I had to redrill one hole in the drivers flange, no big deal & on this one (eBay $189 2 row special to my door) there was no provision to mount a shroud & reportedly some of em ain't flat but reportedly that issue has been resolved & there was a guy on here who sold em (& guaranteed em). there was a comment about the core tube sizes being a bit small (than OE ones) but mine cooled fine but a DD 318 would not even come close to pushing/testing its cooling limits. that is all I can come up with & I would not hesitate to get anouther one IF it has the capacity to mount/use a shroud. EDIT or if a shroud can be mounted to it as is.
[Re: 65fury]
#2431054
01/08/18 02:26 PM
01/08/18 02:26 PM
Posts: 416 Georgia
KingTuna
Georgia
On the alternator, you could probably get one from the parts store for a 73 New Yorker with the 400. These are duel field alternators, so you have to do a little wiring to make it work, but it's easy. google single field to dual field alternator mopar and you'll find a diagram. My car charges much better now
2014 Ram 1500 Pentastar V6 1966 Fury II 4 door
[Re: 65fury]
#2431551
01/09/18 12:45 PM
01/09/18 12:45 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Can also depend on how much you want to spend. A guy I know put a direct fit aluminum rad in his 65 Coronet and paid over $500 dollars for it. I bought an Afco aluminum rad from Mancini for about $300 that fit in fine but had no holes in the brackets as I had to just mark and drill holes in the brackets. Course I did not mind since it was over $200 dollars cheaper and it cools my 63 good. Ron
[Re: 71birdJ68]
#2431613
01/09/18 02:28 PM
01/09/18 02:28 PM
Speedway motors (A mile from me & my former employer) sells a reasonable priced alum radiator. I've used several of em with no issues. They do shipping.
[Re: 65fury]
#2431642
01/09/18 03:19 PM
01/09/18 03:19 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
Gotm a 150 buck Champion for my built 65 440.Runs under 190 all day long.Fit was decent.Did have to get an adapter for lower hose because it was 1 3/4 and rad was 1 1/2.Less than 6 bucks at Advance.Rocky
Chrysler Firepower
[Re: 65fury]
#2432022
01/10/18 01:52 AM
01/10/18 01:52 AM
I forgot to ask the most important question which is how hot is it running? is this with a known good mechanical gauge? I'm assuming you are on ported. what is your initial? when you are moveing what does the temp drop to? Was it OK before the original rebuild? (if that info is available). how far into the shroud is the fan located? how many blades? was the rad rodded out or a new core (which it sounded like).
[Re: 65fury]
#2432190
01/10/18 02:12 PM
01/10/18 02:12 PM
Posts: 2,271 central IL reg Nov 18, 1999
Stroker
I'm watching this, I have a '66 Town & Country 440 TNT ordered w/o AC. It has the small radiator and gets hot idling, I put a stock metal shroud on it with a 7 blade fan and that really didn't do much. I'm thinking about going with a US Radiator 22" copper/brass core. I'd like it to look close to stock.
