Stage IV update!!!!!!
#2412406
12/02/17 09:16 PM
12/02/17 09:16 PM
Posts: 734 New York
R/T1968R/T
Have a set of Stage IV heads that are milled .080. If i use the 452 chamber size it looks like they could be 75-76 ccs? .080 divided by .0062 for every cc = 12.9 ccs
Re: 452 Cylinder head chamber similar to stage IV ?
[Re: R/T1968R/T]
#2412415
12/02/17 09:31 PM
12/02/17 09:31 PM
Posts: 43,127 Bend,OR USA
Stock 452 heads check above 90 CC, at least all of the ones I have checked did I think the stock uncut Stage Four heads where large like that also, maybe 84.0 CC to start with, maybe not
[Re: R/T1968R/T]
#2412698
12/03/17 04:28 PM
12/03/17 04:28 PM
The brand and size of the valves, how the valve job was done, how many valve jobs have been done, how big they actually were to start with, and how much they've been milled are all factors in what size the chambers are.
If you really want to know...... You have to measure them.
[Re: LaRoy Engines]
#2412783
12/03/17 07:58 PM
12/03/17 07:58 PM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
.......why don't we just measure these things to know for sure, instead of guessing? Hmmm.
[Re: R/T1968R/T]
#2412803
12/03/17 08:43 PM
12/03/17 08:43 PM
Posts: 734 New York
R/T1968R/T
Youre right I shouldnt guess. I have the plexiglass already just ordered a graduated cylinder.
[Re: R/T1968R/T]
#2413273
12/04/17 09:58 PM
12/04/17 09:58 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
the only way to have the exact number is to cc them....that being said I had a set of those heads new right outta the box years ago and did not measure them but having seen many many bb mopar heads I will say they started out the same as any 452 head...BIG theres a reason they were cut .080 thou...
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
Re: Stage IV update!!!!!!
[Re: R/T1968R/T]
#2414188
12/06/17 02:07 PM
12/06/17 02:07 PM
The chamber diameter is roughly 4.250........ At .080 that works out to about 18.6cc worth of milling.
Installing larger valves, along with using valves with flatter heads reduces chamber volume.
67 + 18.6 = 85.6cc.
I can see that as a starting point with oversized aftermarket valves.
The outer row of head bolt bosses are a nominal 1.00" thick, stock. If you measure a few it should give you an idea how close to that .080" has been cut off the decks.
This is why you measure instead of assume. They are what they are.
[Re: R/T1968R/T]
#2415175
12/08/17 12:41 PM
12/08/17 12:41 PM
Posts: 3,916 usa
lewtot184
usa
I think with out any quench Im screwed. I can always put them on a smog motor or a motor with L2266 which are .090 in the hole. there are quench dome pistons.
[Re: R/T1968R/T]
#2415215
12/08/17 01:51 PM
12/08/17 01:51 PM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
I think with out any quench Im screwed. I can always put them on a smog motor or a motor with L2266 which are .090 in the hole. How deep are the open part of the chambers now? You can get a piston made that will give you quench and a streetable compression, I had Diamond make me some a few years ago. Sorry for the crappy picture, it's a D shaped dome with a D shaped dish, 9.5 compression 440 , though your heads being as small as there are might be a challenge on the dish size ?
