#2412406 - 12/02/17 06:16 PM Stage IV update!!!!!!
R/T1968R/T Offline
Loc: New York
Have a set of Stage IV heads that are milled .080. If i use the 452 chamber size it looks like they could be 75-76 ccs? .080 divided by .0062 for every cc = 12.9 ccs
Edited by R/T1968R/T (12/05/17 08:10 PM)
#2412415 - 12/02/17 06:31 PM Re: 452 Cylinder head chamber similar to stage IV ? [Re: R/T1968R/T]
Loc: Bend,OR USA
Stock 452 heads check above 90 CC, at least all of the ones I have checked did shruggy
I think the stock uncut Stage Four heads where large like that also, maybe 84.0 CC to start with, maybe not confused
Edited by Cab_Burge (12/02/17 06:31 PM)
#2412606 - 12/03/17 07:49 AM Re: 452 Cylinder head chamber similar to stage IV ? [Re: R/T1968R/T]
LaRoy Engines Offline
Loc: Idaho
When we are putting together our bazillion dollar engines, why don't we just measure these things to know for sure, instead of guessing?
#2412698 - 12/03/17 01:28 PM Re: 452 Cylinder head chamber similar to stage IV ? [Re: R/T1968R/T]
fast68plymouth Offline
Loc: So. Burlington, Vt.
The brand and size of the valves, how the valve job was done, how many valve jobs have been done, how big they actually were to start with, and how much they've been milled are all factors in what size the chambers are.
If you really want to know...... You have to measure them.
68 Plymouth Satellite, 383, stock 906's, 3550lbs, 11.18 @ 123, 1.51 60' PRH is a Comp Cams W/D......competitive pricing on entire line. Custom cams available. ** dealer for Indy Cylinder Heads **
#2412783 - 12/03/17 04:58 PM Re: 452 Cylinder head chamber similar to stage IV ? [Re: LaRoy Engines]
BSB67 Online   content
Loc: Prospect, PA
Originally Posted By LaRoy Engines
.......why don't we just measure these things to know for sure, instead of guessing?
Hmmm.
500" NA, Eddy head, pump gas, exhaust manifold with 2 1/2 exhaust with tailpipes 4150 lbs with driver, 3.23 gear, stock converter 11.68 @ 120.2 mph
#2412803 - 12/03/17 05:43 PM Re: 452 Cylinder head chamber similar to stage IV ? [Re: R/T1968R/T]
R/T1968R/T Offline
Loc: New York
Youre right I shouldnt guess. I have the plexiglass already just ordered a graduated cylinder.
Edited by R/T1968R/T (12/03/17 05:57 PM)
#2413122 - 12/04/17 01:03 PM Re: 452 Cylinder head chamber similar to stage IV ? [Re: R/T1968R/T]
dogdays Offline
Have the intake faces been milled as well? With 0.080 taken off this needs to be done.
R.
#2413245 - 12/04/17 06:18 PM Re: 452 Cylinder head chamber similar to stage IV ? [Re: dogdays]
R/T1968R/T Offline
Loc: New York
Intake faces where milled accordingly. Manley stainless valves 2.14 In 1.84 ex, ported and polished. These heads were on a mild 440 that went 10.77 in a full interior 69 Charger. I know they flow good, just want to work out a good compression for a street car.
#2413273 - 12/04/17 06:58 PM Re: 452 Cylinder head chamber similar to stage IV ? [Re: R/T1968R/T]
yella71 Offline
Loc: New Jersey, USA
the only way to have the exact number is to cc them....that being said I had a set of those heads new right outta the box years ago and did not measure them but having seen many many bb mopar heads I will say they started out the same as any 452 head...BIG theres a reason they were cut .080 thou...
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
#2413893 - 12/05/17 08:08 PM Stage IV update!!!!!! [Re: R/T1968R/T]
R/T1968R/T Offline
Loc: New York
So, I ccd the heads, Four different cylinders and all very close results. 67ccs!!!!! The math doesnt add up though. .080 milled should not come out this low. Take a look.
[img:center]http://imgbox.com/TzlEWqWG[/img]
[img:center]http://imgbox.com/hGtzAPsO[/img]
[img:center]http://imgbox.com/SKDI7MWj[/img]
[img:center]http://imgbox.com/Bkjkr5Tx[/img]
#2414188 - 12/06/17 11:07 AM Re: Stage IV update!!!!!! [Re: R/T1968R/T]
The chamber diameter is roughly 4.250........ At .080 that works out to about 18.6cc worth of milling.
Installing larger valves, along with using valves with flatter heads reduces chamber volume.
67 + 18.6 = 85.6cc.
I can see that as a starting point with oversized aftermarket valves.
The outer row of head bolt bosses are a nominal 1.00" thick, stock.
If you measure a few it should give you an idea how close to that .080" has been cut off the decks.
This is why you measure instead of assume.
They are what they are.
#2414315 - 12/06/17 03:01 PM Re: Stage IV update!!!!!! [Re: R/T1968R/T]
lewtot184 Offline
Loc: usa
I get 19cc for the .080" mill. my stage V's were right at 88cc new. same chamber as stage IV's.
#2414382 - 12/06/17 06:10 PM Re: Stage IV update!!!!!! [Re: R/T1968R/T]
Loc: Bend,OR USA
Polishing the chambers make them bigger than stock work
Cutting the heads makes the combustion chambers smaller shruggy
As far as your reading on that digital micrometer are you putting any pressure on the gauge to make it tight up against the head? If so ,don't tsk
Do you have a decent regular, non digital, outside micrometer that you can set the calibration on? If so compare your readings between the two gauges and let us know what you find scope thumbs
If not don't worry about that now, you already know the CC up
I have seen as much as 4.2 CC differences in stock wedge and hemi heads between all four chambers on those heads shock shruggy
#2414959 - 12/07/17 07:37 PM Re: Stage IV update!!!!!! [Re: Cab_Burge]
dogdays Offline
Regardless of what you should have, 67cc is what you've got. It makes no sense to worry about what you've measured or why it is that number. It is what it is.
on a .030 over 440 with Sixpack pistons and a 12cc head gasket you're looking at 10.9:1 compression. That's high for pump gas.
R.
#2415003 - 12/07/17 09:00 PM Re: Stage IV update!!!!!! [Re: dogdays]
R/T1968R/T Offline
Loc: New York
I think with out any quench Im screwed. I can always put them on a smog motor or a motor with L2266 which are .090 in the hole.
#2415175 - 12/08/17 09:41 AM Re: Stage IV update!!!!!! [Re: R/T1968R/T]
lewtot184 Offline
Loc: usa
there are quench dome pistons.
#2415215 - 12/08/17 10:51 AM Re: Stage IV update!!!!!! [Re: R/T1968R/T]
JohnRR Offline
Loc: U.S.S.A.
How deep are the open part of the chambers now? You can get a piston made that will give you quench and a streetable compression, I had Diamond make me some a few years ago.
Sorry for the crappy picture, it's a D shaped dome with a D shaped dish, 9.5 compression 440 , though your heads being as small as there are might be a challenge on the dish size ?
#2415285 - 12/08/17 01:27 PM Re: Stage IV update!!!!!! [Re: R/T1968R/T]
lewtot184 Offline
Loc: usa
a kb184 with a .060" head gasket may be a perfect fit.
25,067 Registered Members
185,546 Topics
water pump removal
by blaze
01/16/18 07:27 PM
Will there be a New California?
by astjp2
01/16/18 07:11 PM
Par-Al-Ketone
by astjp2
01/16/18 06:21 PM
Pitman arm question
by mickm
01/16/18 06:20 PM
