Page 2 of 2 < 1 2
#2401347 - 11/10/17 09:29 AM Re: are you using your factory mopar jack if you have flat [Re: moparpro]
NachoRT74 Offline
Loc: Caracas, Venezuela, SouthAmeri...
for a flat tire, I still trust on the original jack and use it if needed... no probs on that.
#2401557 - 11/10/17 05:17 PM Re: are you using your factory mopar jack if you have flat [Re: DZJim]
71GTX471 Online   content
Loc: Harriman NY
Used to have an old Sears scissors jack that worked real good.
Grew up with one blue & red it was the main family jack for years did everything with it until I finely got a hyd.floor jack from sears they would have a $99 special buy a jack & get 2 free jack stands.Still have the jack & stands.
Edited by 71GTX471 (11/10/17 05:18 PM)
#2401569 - 11/10/17 05:38 PM Re: are you using your factory mopar jack if you have flat [Re: 71GTX471]
bboogieart Offline
Loc: Lost and Spaced
Used a bumper jack on the right rear on a '70 Fury back in the 80's once. whistling
It wouldn't lift the car high enough to get the tire off the ground. shocked
I now take care to make sure all tires and brakes are kept in good driving condition.
Just in case though, I have a good spare, small floor jack, 2 jack stands, a piece of micro lam. and a 1/2" drive socket set with breaker bar, as well as a small tool kit in all my rides, except the Shovel Head of course...
I have mechanical Aptitude.
I can screw up anything.
#2401757 - 11/11/17 12:39 AM Re: are you using your factory mopar jack if you have flat [Re: moparpro]
skyhawk61 Offline
Loc: hickory nc USA
I leave the original jack for the shows, but carry one of these in all my old Mopars. GM unit works like a floor jack, so bumpers don't get twisted and scratched. I removed the round "thingie" on the end, welded on a plate with "lips" to keep it from sliding off the car's frame. Good footprint, very stable, and, once upon a time, cheap as dirt at the junkyard.
#2401783 - 11/11/17 07:36 AM Re: are you using your factory mopar jack if you have flat [Re: moparpro]
Loc: Harriman NY
Skyhawk that's pretty cool what model did they come in.
#2401907 - 11/11/17 11:22 AM Re: are you using your factory mopar jack if you have flat [Re: 71GTX471]
skyhawk61 Offline
Loc: hickory nc USA
71GTX471, they came in GM Caprice, Impala,Cutlass, Monte Carlo, Grand Prix models 1978-88, and some of the smaller Cadillacs. Sometimes found in Camaro and Firebird 82-02, but with a different frame plate (no round "thingie" on the end that goes under the frame.)
#2403005 - 11/13/17 10:53 AM Re: are you using your factory mopar jack if you have flat [Re: moparpro]
a12rag Offline
Loc: Calgary, Alberta Canada
In 99 I went to Chryslers in Carlisle in my 74 Duster360. Once there, I realized I had a rear spring shackle break (but it broke so it was keyed together "most"of the time) . . . rather than trust my body to the bumper jack, I bought a small floor jack that came with a plastic carrying case, along with new shackles and repaired the car in motel parking lot . . . still have the jack . . . sure the bumper jacks work, but the floor jack is just easier and can use it on any vehicle/trailer !! . . .
Page 2 of 2 < 1 2
25,343 Registered Members
190,198 Topics
Most users ever online: 1,417 @ 06/18/18 08:39 PM
Bench testing reverse switch A833
by 69hemibeep
06/20/18 05:50 PM
Maximum CR closed chamber w2 heads 0.040 quench- pump gas
by domingo
06/20/18 05:19 PM
65 B-Body Master Cylinder Conversion
by vjb
06/20/18 04:53 PM
68 Hemi Road Runner project Dallas craigslist
by TiMopar
06/20/18 04:06 PM
