GREEN BEARING AND AXLE SEAL #2390113
10/20/17 12:20 AM
10/20/17 12:20 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Still need to use a separate axle seal or does the green bearing assembly take care of it.
Re: GREEN BEARING AND AXLE SEAL [Re: A/MP] #2390175
10/20/17 02:41 AM
10/20/17 02:41 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
not supposed to need a seal . I do as I have had some leak through the bearing .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm
Power by Tex's Automotive
Re: GREEN BEARING AND AXLE SEAL [Re: A/MP] #2390357
10/20/17 05:02 PM
10/20/17 05:02 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Yes use the seal. The greenies are not totally sealed and oil will weep through as mentioned above and will wash out the grease that's in them possible leaving them to go dry as not enough oil is getting to them. So I would recommend using the seals.
Re: GREEN BEARING AND AXLE SEAL [Re: A/MP] #2390364
10/20/17 05:19 PM
10/20/17 05:19 PM
It really depends on which version of the bearings you have, if has the press on retainer on the front of the bearing I would use the inner seal with them up
If is the one that the outer retainer is loose they haven't leak on any of my cars, race or street, with out the inner seals up shruggy
Re: GREEN BEARING AND AXLE SEAL [Re: A/MP] #2390385
10/20/17 06:12 PM
10/20/17 06:12 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
So with a seal do you expect to get some kind of leakage to wet the race/bearing? Should I add a dash of gear oil to the bearing assembly?
Re: GREEN BEARING AND AXLE SEAL [Re: A/MP] #2390390
10/20/17 06:22 PM
10/20/17 06:22 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Just lube the lip seal. Mine never leaked.
Re: GREEN BEARING AND AXLE SEAL [Re: rickraw] #2390611
10/21/17 12:19 AM
10/21/17 12:19 AM
iagree
I lube the O ring on the bearing also as well as the inner seal and some grease on the seal area on the axle up
