Re: Factory Throttle Pedal and Rod to Cable
[Re: 71birdJ68]
#2326955
06/26/17 01:54 PM
06/26/17 01:54 PM
cudaman1969
fredericksburg,va
I had a 61 Valiant that had a rod set up. That one twisted instead of push pull. I did the opposite, eliminated the cable and used a rod on my 64 Plym, Why do you want to change? Missing-broken parts? Check with Lokar Cable they might have something that will work.
[Re: cudaman1969]
#2326985
06/26/17 02:55 PM
06/26/17 02:55 PM
Posts: 1,335 Oregon
earlymopar
The reason for the change is that I'm swapping the slant 6 for a Poly 318 and my new manifold and carburetor is quite a bit higher than the OEM rods and pivot points from the slant 6 linkage. I've also given thought to just making a new, longer set of rods. I have a Lokar cable left over from another project that is planned for the pickup if I go the cable route. I just wanted to see how others have gone after this same issue. Interestingly, the factory linkage is very simple and I think easy to adapt to the new engine and intake set-up. -EM
[Re: earlymopar]
#2327867
06/28/17 01:49 AM
06/28/17 01:49 AM
Posts: 20,169 Park Forest, IL
slantzilla
Park Forest, IL
IIRC, the problem is that the pedal hinges on the floor, so it is pushing the rod. Not real sure how you could get it to pull a cable.
On my '66 Valiant I just used a later cable style pedal, but I wasn't concerned about looks. 99% of the people who looked in the car never knew the difference anyway.
[Re: slantzilla]
#2327962
06/28/17 10:40 AM
06/28/17 10:40 AM
On my '66 Valiant I just used a later cable style pedal. that's what I did, 2 holes in the floor to mount it & that very quickly solved that problem. just get a JY one with the right length cable.
[Re: bbtrux]
#2327970
06/28/17 10:50 AM
06/28/17 10:50 AM
^^^ Ding ding ding We may have a winna.
