Re: Distributor
[Re: cudaman1969]
#2309699
05/23/17 11:54 AM
05/23/17 11:54 AM
Posts: 3,871 Smyrna, South Carolina
STEFF
I think the MSD6 Hemi kit is around 7-800ish? How is timing adjusted with that system? Laptop using the MSD Pro Data Software. Connect the dots in a timing map. Super Simple!
Re: Distributor
[Re: STEFF]
#2309762
05/23/17 01:49 PM
05/23/17 01:49 PM
Posts: 8,237 fredericksburg,va
cudaman1969
fredericksburg,va
I think the MSD6 Hemi kit is around 7-800ish? How is timing adjusted with that system? Laptop using the MSD Pro Data Software. Connect the dots in a timing map. Super Simple! Ok, if pointed in the right direction I can figure it out, thanks
Re: Distributor
[Re: cudaman1969]
#2310657
05/24/17 11:06 PM
05/24/17 11:06 PM
STEFF
You dont need all that. Just the controller and wiring harness. A distributor is a step backwards. Plus you dont get to take advantage of the dual plug with the distributor.
Re: Distributor
[Re: cudaman1969]
#2310829
05/25/17 11:05 AM
05/25/17 11:05 AM
cudaman1969
fredericksburg,va
How is timing adjusted, chip reader or laptop? What about mixture or if different parts added? Just read the Jegs add, one of my questions answered.
Re: Distributor
[Re: cudaman1969]
#2310939
05/25/17 02:02 PM
05/25/17 02:02 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
I think he is asking about fuel, The Hemi-6 only controls ignition, it's not for fuel
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
