Distributor #2307592
05/19/17 08:59 PM
05/19/17 08:59 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Is the dist adapter still made? If so by whom. I looking at a mechanical way to fire the coil packs.
Re: Distributor [Re: cudaman1969] #2307599
05/19/17 09:08 PM
05/19/17 09:08 PM
USA
hudsonhornet7x Offline
USA
Arrow Racing makes a complete front drive that includes a crane distributor.
http://www.arrowracingengines.com/61hemidistributorkit.html
I just ordered one of their intakes and they were very easy and pleasant to deal with.
Re: Distributor [Re: cudaman1969] #2307730
05/20/17 01:54 AM
05/20/17 01:54 AM
fredericksburg,va
fredericksburg,va
Wow, $1670, I had to ask
Re: Distributor [Re: cudaman1969] #2307734
05/20/17 02:06 AM
05/20/17 02:06 AM
USA
USA
Yep, An MSD Hemi 6 box will do the same thing and it's much much cheaper.
Re: Distributor [Re: cudaman1969] #2307982
05/20/17 03:26 PM
05/20/17 03:26 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I think the MSD6 Hemi kit is around 7-800ish?
Re: Distributor [Re: WO23Coronet] #2309658
05/23/17 10:45 AM
05/23/17 10:45 AM
fredericksburg,va
fredericksburg,va
How is timing adjusted with that system?
Re: Distributor [Re: cudaman1969] #2309699
05/23/17 11:54 AM
05/23/17 11:54 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Laptop using the MSD Pro Data Software. Connect the dots in a timing map. Super Simple!
Re: Distributor [Re: STEFF] #2309762
05/23/17 01:49 PM
05/23/17 01:49 PM
fredericksburg,va
fredericksburg,va
Ok, if pointed in the right direction I can figure it out, thanks
Re: Distributor [Re: cudaman1969] #2310647
05/24/17 10:56 PM
05/24/17 10:56 PM
Jamey Online content
Jamey  Online Content
http://www.jegs.com/i/MSD-Ignition/121/6013K/10002/-1
Not much cheaper than the distributor setup. If I go carb, I'm leaning towards the arrow racing setup. Looks really cool and makes the engine look like it was meant to be there.
Re: Distributor [Re: cudaman1969] #2310657
05/24/17 11:06 PM
05/24/17 11:06 PM
STEFF Offline
STEFF  Offline
You dont need all that. Just the controller and wiring harness. A distributor is a step backwards. Plus you dont get to take advantage of the dual plug with the distributor.
Re: Distributor [Re: cudaman1969] #2310668
05/24/17 11:48 PM
05/24/17 11:48 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Yeah the controller with harness is just over $700, factory coils are fine
Re: Distributor [Re: cudaman1969] #2310829
05/25/17 11:05 AM
05/25/17 11:05 AM
fredericksburg,va
fredericksburg,va
How is timing adjusted, chip reader or laptop? What about mixture or if different parts added?
Just read the Jegs add, one of my questions answered.
Re: Distributor [Re: cudaman1969] #2310845
05/25/17 11:46 AM
05/25/17 11:46 AM
STEFF Offline
STEFF  Offline
Timing is adjusted using free MSD Pro data software on a Laptop. Very easy to create timing maps and transfer them to & from the laptop to the MSD Controller.
Not sure what you mean about mixtures of different parts.
Re: Distributor [Re: cudaman1969] #2310939
05/25/17 02:02 PM
05/25/17 02:02 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I think he is asking about fuel,
The Hemi-6 only controls ignition, it's not for fuel
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Distributor [Re: cudaman1969] #2310959
05/25/17 02:37 PM
05/25/17 02:37 PM
STEFF Offline
STEFF  Offline
Correct.
