stage v rocker shaft stand question #2293030
04/24/17 12:48 AM
04/24/17 12:48 AM
new york
68HEMIRR Offline OP
68HEMIRR  Offline OP
new york
getting my hemi back together and i torqued down the heads and now i was looking at the torque for my stage v rocker shaft stand bolt torque.....book says 30 ft lbs of torque....that would be for cast steel stands right?.....these are stage v aluminum stands.....would it be less?.....i dont want to strip them out
thanks
BORN TO BE WILD
Re: stage v rocker shaft stand question [Re: 68HEMIRR] #2293092
04/24/17 04:08 AM
04/24/17 04:08 AM
The bolts hold the shafts into the stands, there is no load on the bolts so 25 to 30 ft. lbs. with oil should be fine thumbs
Anti seize might be better than oil for future maintenance work
Re: stage v rocker shaft stand question [Re: Cab_Burge] #2293109
04/24/17 09:11 AM
04/24/17 09:11 AM
new york
68HEMIRR Offline OP
68HEMIRR  Offline OP
new york
thanks....
BORN TO BE WILD
Re: stage v rocker shaft stand question [Re: 68HEMIRR] #2293309
04/24/17 05:02 PM
04/24/17 05:02 PM
an8sec70cuda Offline
I still torque mine to 30 ft. lbs. even though I also have aluminum stands.
CHIP
'06 GMC 2500HD LBZ Duramax
