electronic distributor #999781
05/25/11 06:10 PM
05/25/11 06:10 PM
st.cloud fl
d-150 Offline OP
Smarter than a 5th grader?
d-150  Offline OP
st.cloud fl
trying to hookup summit racing box. hooked it up no spark called summit tech bad box.got another hooked up got spark when doing test but no fire when hooked up.everything worked with factory box before summit box. i narrowed down to distributor how to test to make sure it is the distributor.
Re: electronic distributor [Re: d-150] #999782
05/25/11 06:29 PM
05/25/11 06:29 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
before you start throwing parts at it, can you put back the original ign and test it that way? have you changed anything with the distributor to make you suspect it went south?
Re: electronic distributor [Re: d-150] #999783
05/25/11 06:31 PM
05/25/11 06:31 PM
BA, OK
O
orangedustya Offline
O
BA, OK
We had same problem on the Duster. Wired it up just like instructions said but no fire. We switched the two distributor wires and its worked fine ever since.
Brad
Re: electronic distributor [Re: orangedustya] #999784
05/25/11 10:21 PM
05/25/11 10:21 PM
st.cloud fl
d-150 Offline OP
d-150  Offline OP
st.cloud fl
just got done. changed the dist. guts while in their put performance springs in.what a difference popped off and revved quick. i think first box fried dist.
