Edelbrock heads on small block stroker #999714
05/25/11 03:27 PM
05/25/11 03:27 PM
SoCal
dodgex5 Offline OP
dodgex5  Offline OP
SoCal
Does anyone know of any horsepower limitations when using Edelborck heads on a stroked 340? I'm hoping to get 550 horsepower using a kit with a forged crank.
Re: Edelbrock heads on small block stroker [Re: dodgex5] #999715
05/25/11 03:31 PM
05/25/11 03:31 PM
NY usa
540challenger Offline
NY usa
It is do able with the eddies but it is going to take some porting to get you there.
Re: Edelbrock heads on small block stroker [Re: dodgex5] #999716
05/25/11 04:21 PM
05/25/11 04:21 PM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
With stock flow in the upper 240-250+ range, it would be big stretch to get the HP you desire...even to get 500hp, while doable, would take quite a bit of cam to get there.
for whatever it's worth, a generic formula that applies only to 8 cylinder engines is that for every cfm of flow, a head can support 2.05 hp. IE, heads that flow 250 cfm can support as much as 512.5 hp...and that really doesn't change whether it's a stroker or not...the peak rpm and torque changes though.
As stated, a set of professionaly ported eddies can do the trick.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: Edelbrock heads on small block stroker [Re: dodgex5] #999717
05/25/11 07:21 PM
05/25/11 07:21 PM
AndyF Offline
AndyF  Offline
If you look in the tech archives you'll see a couple of articles that I wrote for Mopar Muscle magazine on a 427 inch small block that we built last year. We used Edelbrock heads with the Stage III porting. Those heads will easily support 550+ hp. That 427 made a little over 500 hp with a super small cam and carb. It isn't a drag race motor so we didn't put a big cam or a big carb on it.
Re: Edelbrock heads on small block stroker [Re: AndyF] #999718
05/25/11 07:35 PM
05/25/11 07:35 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
At some point wouldn't a person be money ahead to just buy a better set of heads than paying someone to max port a set of Edelbrock heads?
Re: Edelbrock heads on small block stroker [Re: Neil] #999719
05/25/11 08:19 PM
05/25/11 08:19 PM
SoCal
dodgex5 Offline OP
dodgex5  Offline OP
SoCal
If not eddys, what are your suggestions? And what are my intake manifold choices? This is not necessarily a drag motor but will see some quarter mile use. I'll probably keep the 3:91 gears and it is a 4 speed.
Re: Edelbrock heads on small block stroker [Re: dodgex5] #999720
05/25/11 09:16 PM
05/25/11 09:16 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I'm not an engine builder or a head porter. I was just asking the question to see how much an all- out port job + shipping to and from a reputable head porter would cost vs just buying heads that will deliver the power level you want without having to spend extra money on them.
I went with W2 econo heads on mine. The bare heads weren't all that expensive, but the offset rockers and shaft setups were rather spendy.
I know Indy makes several small block heads that are likely have more potential than Edelbrocks.
Mopar Performance used to sell Commando heads. I don't know where they rank at. MP W5 heads are good, but you would be stuck with finding a used set these days.
Brodix makes Mopar smallblock heads too.
http://www.brodix.com/heads/b1.php
Talking to RyanJ or a few of the other guys on the race only board that deal in smallblocks for a living would be a good idea to help narrow down your choices.
