Brake drag? #999532
05/25/11 08:29 AM
05/25/11 08:29 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
My wheels get quite hot when I drive the Charger. I recently upgraded to discs up front (ebay kit manufactured by MBM - same as MP Brakes but with universal dual 8" booster and GM master).
How hard should it be to turn the wheels by hand? When I jack up the car I can spin the wheel just over once - and I have to use both of my hands! Is this considered normal or do I have excessive drag?
Check wheel bearing preload and it's fine - seems to be the brakes.
Will crack open a bleeder to see if wheels spin more freely then. Any other ideas?
Re: Brake drag? [Re: DGS] #999533
05/25/11 08:56 AM
05/25/11 08:56 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Sounds like they are hanging a bit.Most PBs have an adjustable pushrod.You can adjust it either in or out.Rocky
Chrysler Firepower
Re: Brake drag? [Re: therocks] #999534
05/25/11 09:28 AM
05/25/11 09:28 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
I forgot to mention that I already loosened the master cylinder a bit so that the push rod wouldn't touch the master cylinder - didn't improve anything.
Maybe I have to open the bleeders and check again.
Re: Brake drag? [Re: DGS] #999535
05/25/11 09:29 AM
05/25/11 09:29 AM
Excesssive drag. some calipers are like that & I R&R them to take care of it (cheap stock ones tho). As Rock said I'd check the adj pushrod clearance & if good then take off & remount the calipers as they might be hanging up a bit from the mounting then replace em as a last resort
Re: Brake drag? [Re: RapidRobert] #999536
05/25/11 09:38 AM
05/25/11 09:38 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
alright, I'll check the pushrod first. Calipers are new so I didn't disassemble them before I installed the brake kit.
Re: Brake drag? [Re: DGS] #999537
05/25/11 05:05 PM
05/25/11 05:05 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Somehow its holding residual pressure. The obvious question is, did you get a M/C that is related to disc brakes? Drum M/C's are known to hold residual pressure.
Re: Brake drag? [Re: Viol8r] #999538
05/25/11 05:59 PM
05/25/11 05:59 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Supposedly they only sell disc masters. There shouldn't be a residual valve in the master.
The brakes are slider types. Would it affect pad return if I overtorqued the anti-rattle springs (they attach to the brake adapter but put pressure on the caliper)?
