Green loop wire on MSD digital 6? #999527
05/25/11 07:14 AM
05/25/11 07:14 AM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
I have a MSD digital 6 on my 74 scamp 440 with a mallory unilite dist. The directions are not very clear on if I need to cut the green loop wire or not. Any experiance out there?
Re: Green loop wire on MSD digital 6? [Re: mopfried] #999528
05/25/11 03:20 PM
05/25/11 03:20 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
You can go on their website and/or call their tech line.
Re: Green loop wire on MSD digital 6? [Re: mopfried] #999529
05/25/11 05:14 PM
05/25/11 05:14 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Per MSD, if you are using a unilite (or any other non-magnetic trigger dist.), dont cut the green "magnetic pickup" loop. You cut it when you run a magnetic pickup distributor. Looks like there is some sort of compensation factor for retard at high RPM's with a magnetic pickup that is activated when the wire is cut.
