727 valve bodies #999466
05/25/11 01:49 AM
05/25/11 01:49 AM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
I have a valve body that I believe is from a 71 big block 727. It does have the comb for the 69-up NSS.
How can I tell the year?
Am I correct that this valve body can be used in a 67 727?
Besides the part-throttle kickdown of the 71, are there any other advantages or disadvantages to the 71 vs. the 67 valve bodies?
Re: 727 valve bodies [Re: Jim_Lusk] #999467
05/25/11 07:51 AM
05/25/11 07:51 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
What's the casting date clock on the VB say , not that that is an indicator of actual year. Someone might be able to identify by the number punched out on the seperator plate . Yes it will work fine in that 67 core .
Re: 727 valve bodies [Re: Jim_Lusk] #999468
05/25/11 03:07 PM
05/25/11 03:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
In the pic below of a '71-later VB notice the steel cover plate on the top of the main VB casting, it has six screws while the '70 and earlier only have four. The PTK module is visible to the left.
Re: 727 valve bodies [Re: John_Kunkel] #999469
05/25/11 03:10 PM
05/25/11 03:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The '69-'70 VB.
Re: 727 valve bodies [Re: John_Kunkel] #999470
05/26/11 02:05 AM
05/26/11 02:05 AM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
Thanks John. The trans the valve body came out of was a 71. I know that because it was behind a 383 and it does match the picture.
Re: 727 valve bodies [Re: Jim_Lusk] #999471
05/26/11 05:11 PM
05/26/11 05:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Is the steel plate punched "934"?
