Wilson shear plate? #999435
05/24/11 11:46 PM
05/24/11 11:46 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I am wondering if anyone here has used a Wilson Shear plate like the one pictured below. I am considering one for my Stage V hemi intake on my 572. Tim
Re: Wilson shear plate? [Re: astjp2] #999436
05/25/11 12:27 AM
05/25/11 12:27 AM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
We run them, picked up 10 hp in our combo.
Re: Wilson shear plate? [Re: astjp2] #999437
05/25/11 01:10 AM
05/25/11 01:10 AM
AndyF Offline
AndyF  Offline
They usually don't fit cast intakes without a lot of grinding.
Re: Wilson shear plate? [Re: astjp2] #999438
05/25/11 02:40 AM
05/25/11 02:40 AM
I've dyno tested one 1.5 inch tall Wilson Manifold Dominator reversion spacer, it was worth 8 HP on a 700+ HP motor on pump gas I'd like to buy another one(cheap ) to run on my tunnel ram
Re: Wilson shear plate? [Re: Cab_Burge] #999439
05/25/11 12:14 PM
05/25/11 12:14 PM
AndyF Offline
AndyF  Offline
I have a whole collection of shear plates including ones from RM, Holley and Wilson.
Re: Wilson shear plate? [Re: AndyF] #999440
05/25/11 02:07 PM
05/25/11 02:07 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
How do they work?
Re: Wilson shear plate? [Re: AndyF] #999441
05/25/11 03:36 PM
05/25/11 03:36 PM
Az
Crizila Offline
Crizila  Offline
Az
Are they mostly used to address reversion or to address fuel distribution / atomization?
Fastest 300
Re: Wilson shear plate? [Re: Crizila] #999442
05/25/11 05:26 PM
05/25/11 05:26 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Wilson claims reversion.....
Re: Wilson shear plate? [Re: AndyF] #999443
05/25/11 06:30 PM
05/25/11 06:30 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
I may be wrong but usually that means they are collecting dust. I also would like to get some input on weather they work or not on a 500 to 600hp motor.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: Wilson shear plate? [Re: astjp2] #999444
05/25/11 06:41 PM
05/25/11 06:41 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
wilson 1" gave me 14hp,right in front of my eyes on the dyno good chit mang
Re: Wilson shear plate? [Re: slippery440] #999445
05/25/11 10:02 PM
05/25/11 10:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I am wondering if that little bit of plenum volume is
the added power... if someone were to just add a plate
that same thickness with 4 holes would it give the
same results
Re: Wilson shear plate? [Re: MR_P_BODY] #999446
05/25/11 10:44 PM
05/25/11 10:44 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
I put 2" spacer on my M1 and yes it helped a bunch. I was wondering about reversion now.I leave off a Tranz brake so there might be nothing wrong there. Its wide open and the car leaves clean. I wonder whats going on at the shift points when the rpm drops.
