340 enigne mount brackets #999410
05/24/11 11:02 PM
05/24/11 11:02 PM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
I think we determined Sunday that I have E body brackets that I thought were A body brackets. Now I'm back on track and looking for the right one. From some pictures I have I believe that the passenger's side for a 318 and a 340 are different as well. Am I right? Will the passenger's side E body bracket work? Can the driver's side be modified to work? Anybody wanta trade?
Careful, your character's showing!
Re: 340 enigne mount brackets [Re: mopar346] #999411
05/24/11 11:32 PM
05/24/11 11:32 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
They are different. Here's a thread that might give you some good info. you can use the 318 mount on the 340 with the use of a spacer.
https://board.moparts.org/ubbthreads/show...part=1&vc=1
65 Barracuda
70 Challenger
Re: 340 enigne mount brackets [Re: jrwoodjoe] #999412
05/24/11 11:48 PM
05/24/11 11:48 PM
mopar346 Offline OP
mopar346  Offline OP
Thanks that thread indicates that the passenger's side is the same for 318 and 340 for an A body. Here is a picture or the 318 mounts.
Re: 340 enigne mount brackets [Re: mopar346] #999413
05/24/11 11:52 PM
05/24/11 11:52 PM
mopar346 Offline OP
mopar346  Offline OP
The 340 mounts, they appear to be clearly different to me. Or are there 4 bolt holes and the bolts are just in different holes?
Re: 340 enigne mount brackets [Re: mopar346] #999414
05/25/11 12:04 AM
05/25/11 12:04 AM
70duster340 Offline
70duster340  Offline
The driver's side 340 mounts are atill available through the dealer, at least they were last year when I bought mine.
Re: 340 enigne mount brackets [Re: 70duster340] #999415
05/25/11 12:06 AM
05/25/11 12:06 AM
mopar346 Offline OP
mopar346  Offline OP
I checked a number today that I got off of e-bay and it wasn't available. THey are checking by application but haven't let me know yet.
Here's the e-bay ad. http://cgi.ebay.com/ebaymotors/NOS-Mopar...=item336694873d
Do you have the part number you purchased?
Re: 340 enigne mount brackets [Re: mopar346] #999416
05/25/11 12:12 AM
05/25/11 12:12 AM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
DOHH! Sorry, I pasted the wrong link.... I corrected it but click here.
65 Barracuda
70 Challenger
Re: 340 enigne mount brackets [Re: jrwoodjoe] #999417
05/25/11 12:17 AM
05/25/11 12:17 AM
mopar346 Offline OP
mopar346  Offline OP
OK, that talks about E body passenger's side bracket being the same so I guess the A body's are the same as well, since the block is the block E or A.
Re: 340 enigne mount brackets [Re: mopar346] #999418
05/25/11 12:19 AM
05/25/11 12:19 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
The pass side brackets are body specific to the A's.
B and E are different and it's the hole orientation on that side as well.
Re: 340 enigne mount brackets [Re: RobX4406] #999419
05/25/11 12:23 AM
05/25/11 12:23 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
ok A-body 273-318-340-360 passenger side engine mounting bracket,all the same 1967-1972. here is a pic of that particular bracket.....look at offset of center bolt holes....
Re: 340 enigne mount brackets [Re: RobX4406] #999420
05/25/11 12:23 AM
05/25/11 12:23 AM
mopar346 Offline OP
mopar346  Offline OP
So both sides E and the A are different, got it. Is the 318 A body passenger's side bracket the same as a 340 A body passenger's side bracket?
Re: 340 enigne mount brackets [Re: Joesixpack] #999421
05/25/11 12:26 AM
05/25/11 12:26 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
B/C/E body 340-360 brackets look like this.
Re: 340 enigne mount brackets [Re: mopar346] #999422
05/25/11 12:26 AM
05/25/11 12:26 AM
RobX4406 Offline
RobX4406  Offline
Yes, same on that side.
Re: 340 enigne mount brackets [Re: RobX4406] #999423
05/25/11 12:30 AM
05/25/11 12:30 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
the 273 a-body passenger bracket is the same however 1 bolt hole is not drilled....you can take and drill straight across to create hole required for 340-360.
Re: 340 enigne mount brackets [Re: RobX4406] #999424
05/25/11 12:30 AM
05/25/11 12:30 AM
mopar346 Offline OP
mopar346  Offline OP
Thanks all and good night, it's past my bedtime.
