Re: HELP !! 340 lifters NOT PUMPING UP !!!
[Re: hulmule]
#99933
08/04/08 10:58 PM
08/04/08 10:58 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
are they making the clatty noise?
are the pushrods too short?
using adjustable rockers? are you using the wrong pushrods with the hydraulic cam?
or how about more info?
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#99934
08/04/08 11:03 PM
08/04/08 11:03 PM
Posts: 1,405 northeast ohio
hulmule
northeast ohio
Tony we changed the push rods because the other were to long.but we cant get some of them to pump up. when you push on the rocker the lifter is soft.you can push the push rod down.all the others are pumped up hard.
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
[Re: hulmule]
#99935
08/04/08 11:22 PM
08/04/08 11:22 PM
hulmule
northeast ohio
If the push rod is shoter than the correct one per say can it not be adjusted by the rocker?I'm starting to think there to short and it doesnt push the lifter down far enought to get oil in to it.? because looking at the lifter you sure have to push it down far to get it to see the oil hole.make sense?the motor had been o ringed before he said( engine builder) and looked like some had tapped some holes, he put the plug where they were.cold 70 psi warms up 25 at idle and rev up and it goes upto 60psi. I was hoping to go to the NATS this week end with it.any help. thanks phil
[Re: tahoechallenge]
#99937
08/05/08 06:24 AM
08/05/08 06:24 AM
hulmule
northeast ohio
he said all the plugs were installed.if the push rod was short but ad the correct adjustment, could it be possible that the rod doesnt push it down enough to let the oil in the lifter though the oil hole??
[Re: hulmule]
#99938
08/05/08 06:32 AM
08/05/08 06:32 AM
hulmule
northeast ohio
well got to go to work ! sure would like a way to figure this out from a engine builder or a reason way they dont pump up !there's got to be a reason before i go to a solid lifter cam. thanks. I'll check later. or my cell is 440 413 7069 you can call me EST 12 to 12:30 my lunch. thanks phil
[Re: hulmule]
#99939
08/05/08 06:37 AM
08/05/08 06:37 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
If the push rod is too short the lifter will still pump up. It will be ultra noisy though because there will be no preload on the lifter plunger as there should be and there will be play unwanted lash between the components.
[Re: MoparforLife]
#99940
08/05/08 07:27 AM
08/05/08 07:27 AM
i had this problem years ago. never figured it out. it was fun adjust the valves (TA rockers) on that set up. half the lifters were hard as a rock and others were just mushy. I run a solid cam now
#99941
08/05/08 09:48 AM
08/05/08 09:48 AM
RapidRobert
Stay with it,it has to be something simple. My suggestion would be to open up the offending lifters & have a look see. thats where the problem is so it might be a good place to start & the oil gallery plugs are DEFINITELY in place? good luck & keep us informed. Inquiring minds want to know.
[Re: RapidRobert]
#99942
08/05/08 09:53 AM
08/05/08 09:53 AM
Posts: 2,505 God's Country Maryland
GODSCOUNTRY340
If his oil galley plugs in the back weren't installed, he'd have massive amounts of oil running out between the block & trans. How long have you had it running? On a new engine sometimes it takes 15 minutes for the lifters to quiet down.
[Re: Dave Watt]
#99946
08/05/08 05:02 PM
08/05/08 05:02 PM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
Seems like mine was left out by the machine shop which left oil pressure low.
Yes, if you pull the distributor and look down and toward the front of the engine that is where the lifter oil gallery plugs is located.
I'd pull the intake if it were mine and run the oil pump with a drill while rotating the engine and see what is going on in there.
[Re: 69Cuda340S]
#99947
08/05/08 05:46 PM
08/05/08 05:46 PM
Posts: 15,487 Florida
scratchnfotraction
did it have the cam broke in correct? did it wipe a lobe? were the lifters you changed still good on the cam side? are they all spinning in the bores? how big of a cam and spring is on it? may just need run in some to get it fully pumped up I cleaned and inspected the stock hydr roller lifters in mine,when I swapped to a roller cam then installed them and they ran for 35 mins at idle before they quit making noise all the way.
[Re: dogdays]
#99949
08/05/08 07:39 PM
08/05/08 07:39 PM
hulmule
northeast ohio
well talked to another engine builder today and he said that he's switching to solid lifters cam because of the poor quality of hydalic lifters.he's had the same problems.plus cut the band on the lifter larger to make sure it was in the bore deep enough.still soft on 2 and 6.well here's comes my first solid lifter cam. it's on order as i type.just makes me mad that i had the motor all painted nice and put together. I even installed it from the bottom with the K member.try to do things right and where did it get me!! a kick in the n#%$.well got to go out and pull the front end of the car. later!!
