I tried painting epoxy upside down under the car today #999302
05/24/11 08:24 PM
05/24/11 08:24 PM
U.S.
basik Offline OP
basik  Offline OP
U.S.
Had a hard time manuvering the gravity-feed gun I have. I guess it's better to use the type of gun that has the cup on the bottom?
Re: I tried painting epoxy upside down under the car today [Re: basik] #999303
05/24/11 08:34 PM
05/24/11 08:34 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Have you looked in the mirror yet?
Re: I tried painting epoxy upside down under the car today [Re: basik] #999304
05/24/11 08:41 PM
05/24/11 08:41 PM
Kirkland, Washington
Pacnorthcuda Offline
Or you can use 3m's flexible liner/cup system. I forget what its called. THey came out with it about 7-8 years ago. It works pretty well until the paint level gets low, then the bag can inhibit flow.
Siphon gun as you have figured out is an option, so is a swivel fitting on your air line, and raising the car as much as possible.
Re: I tried painting epoxy upside down under the car today [Re: Pacnorthcuda] #999305
05/24/11 08:56 PM
05/24/11 08:56 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
You can buy remote pot spray guns too.
Re: I tried painting epoxy upside down under the car today [Re: basik] #999306
05/24/11 11:42 PM
05/24/11 11:42 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Use a siphon fed gun (cup on the bottom)and turn the pickup tube around so it's facing backwards.Use a cheapo hood/facemask from Home Depot, and wear goggles, cause you WILL get covered up with paint!
