Re: Will a 29.5 x 12.5 tire fit in a mini tubed 69 dart?
[Re: MOPARCRAZY]
#999253
05/24/11 05:44 PM
05/24/11 05:44 PM
Posts: 20,679 in a cattle trailer down by th...
Guitar Jones
I had that tire tucked into my Duster but I had to enlarge the wheel opening front and rear. So if you do that I don't see why you couldn't make it fit. You might need to push the quarter out a little though.
[Re: dartman366]
#999258
05/25/11 12:29 AM
05/25/11 12:29 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
29.5 x true 10.5 on a 12" rim is wall to wall on my car.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#999259
05/25/11 11:11 AM
05/25/11 11:11 AM
Posts: 3,210 robin hood country
deaks
robin hood country
I have just fitted full tubs in mine, still stock rails to get 31"x10.5W slicks on, the axle is moved back an inch and lowered around an inch or so. I've also trimmed the lip too around 3/4" and they fit with room to spare. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: 408strokerdart]
#999261
05/26/11 10:57 AM
05/26/11 10:57 AM
Posts: 4,101 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
My rear frame is notched (a bunch) in the wheel tub area and I have 31 X 13 under it, but that is pushing it. I think my frame is notched about 1 3/4" so I don't know how you could fit a 12.5 wide tire under it. Before notching, I had a 29.5 x 10.5 under it and that was about the biggest with adequate tire clearance....people have differing opinions of "adequate clearance" though. I don't like mine to rub if I go over uneven surfaces.
X2...This is my findings as well. I am sure it will be too wide for an unaltered frame.
[Re: MOPARCRAZY]
#999265
05/27/11 08:31 AM
05/27/11 08:31 AM
HardcoreB
Shelby Twp. Mi
Thanks Guys, I am going with Hoosier 30 x 10.5 radial. (it is 29.5 tall) I will make the fit and hope it is enough tire. Thanks for the help! Lon
Some of the Hoosiers are bigger in diameter. If you put that tire on a 12" rim it will be a tight fit in width. The opening will work no problem, provided you move the axle back...like so--->
