Mounting Hole Size For 2-1/16" Gauges #998861
05/24/11 08:28 AM
05/24/11 08:28 AM
Indiana
Y
YO7_A66 Online content OP
YO7_A66  Online Content OP
Y
Indiana
What hole size do you use for mounting the 2-1/16" gauges? I want to slip the body thru a hole and mount them flush.
I have a couple that I want to remount but I need to pickup a hole saw and I am not sure what size to buy.
Re: Mounting Hole Size For 2-1/16" Gauges [Re: YO7_A66] #998862
05/24/11 09:01 AM
05/24/11 09:01 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I cant remember what size I used when I mounted mine.I measured the gauge and found one that was just a bit smaller than the gauge body so the bezel covered the hole.I did have to use a rat tail file to open it up a bit.The gauge fis nice and snug in the hole.I took an old mounting bracket when I bought the hole saw.Rocky
Chrysler Firepower
Re: Mounting Hole Size For 2-1/16" Gauges [Re: therocks] #998863
05/24/11 09:36 AM
05/24/11 09:36 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I did the same thing. I know the hole is smaller than 2 1/16, I think I used a 2" hole saw and then a dremel to open it up a little more to fit the gauge.
left it nice and tight, don't even use the retaining clip that attaches from the back, the gauge fits so snugly into the holes.
**Photobucket sucks**
Re: Mounting Hole Size For 2-1/16" Gauges [Re: 70Cuda383] #998864
05/24/11 07:44 PM
05/24/11 07:44 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I use the retainer on my fuel gauge.Probally dont need it but I feel better with it holding the gauge in the hood scoop.Rocky
Chrysler Firepower
Re: Mounting Hole Size For 2-1/16" Gauges [Re: therocks] #998865
05/24/11 07:56 PM
05/24/11 07:56 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
2" hole saw, then file to de-burr and open up the ID if needed.
Re: Mounting Hole Size For 2-1/16" Gauges [Re: topside] #998866
05/24/11 08:57 PM
05/24/11 08:57 PM
Indiana
Y
Y
Indiana
Thank you all for the replies.
I got home from work and found another 2-1/16" gauge and it measured 2.02" on the body. The bracket that I bought measured 2.08".
It looks like a 2.06" hole saw would work too.
Thanks again.
Re: Mounting Hole Size For 2-1/16" Gauges [Re: YO7_A66] #998867
05/25/11 06:37 PM
05/25/11 06:37 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Thanks again.
Imagine that! A 2 1/16 guage actually fits in a 2 1/16 hole.
Re: Mounting Hole Size For 2-1/16" Gauges [Re: GomangoCuda] #998868
05/25/11 06:54 PM
05/25/11 06:54 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Thanks again.
2 1/16 would be 2.0625. the gauge he measured was 2.02, .04 smaller than 2 1/16...and is just a hair smaller than 2 1/32 (2.0312)
close, but still not a 2 1/16 gauge fitting into a 2 1/16 hole!
Re: Mounting Hole Size For 2-1/16" Gauges [Re: GomangoCuda] #998869
05/25/11 08:44 PM
05/25/11 08:44 PM
Indiana
Y
Y
Indiana
""Imagine that! A 2 1/16 guage actually fits in a 2 1/16 hole.""
A 2-1/16" gauge bracket actualy measured 2.08". This is the reason that I asked the question.
If I make my own bracket, I was after a more precise answer. Since some did not have the actual measurement (including me), I grabbed my calipers once I got home and let the people who were interested know the body measurement.
Thank you for your technical reply.
Re: Mounting Hole Size For 2-1/16" Gauges [Re: YO7_A66] #998870
05/25/11 10:37 PM
05/25/11 10:37 PM
GomangoCuda Offline
GomangoCuda  Offline
The point is that it isn't a precision fit. It called a 2 1/16 guage because it is sized to fit in a 2 1/16 hole with some clearance. They always fit pretty loose in the brackets. If the bracket hole is big enough to slide the guage in and small enough so that the guage flange covers the hole it will work fine. Stewart Warner says their guage is 2.04, VDO is 2.05 and Autometer just says theirs fits in a 2 1/16 hole. Since you are wanting a more precise fit then you did the right thing by measuring the guage.
Re: Mounting Hole Size For 2-1/16" Gauges [Re: YO7_A66] #998871
05/26/11 08:56 AM
05/26/11 08:56 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
It depends where you are mounting the gauge also.I have a set of hole saws.When I put my gauge in the hood scoop I first drilled a piece of scrap sheet metal.Tried the gauge in it.Its easier to drill some holes in scrap than try to repair a hole thats too big in the car.Rocky
Chrysler Firepower
Re: Mounting Hole Size For 2-1/16" Gauges [Re: YO7_A66] #998872
05/26/11 11:46 AM
05/26/11 11:46 AM
AndyF Offline
AndyF  Offline
When I make a gauge panel I usually cut the hole at 2.070 for the 2 1/16 gauges and 2.630 for the 2 5/8 gauges. The body of the gauges is usually a small amount under the states size.
