are suspension torque specs the same #998853
05/24/11 07:35 AM
05/24/11 07:35 AM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
i need lca,bj,tr, ect ect .i dont have a manual for a 61 newport,but have newer books .would a 73 and a 61 be the same?as far as torque values go?
Re: are suspension torque specs the same [Re: mcmopars] #998854
05/24/11 06:22 PM
05/24/11 06:22 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
As long as the bolts are the same size and thread pitch the torques should be the same .
Re: are suspension torque specs the same [Re: JohnRR] #998855
05/24/11 06:58 PM
05/24/11 06:58 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
the ones that really concern me are the lca bushings nut.the tie rods and ball joints should be close .the torsion bar adjustment is at the rear,not in the arm itself as with newer setup. im guessing as tight as i can get them on the lowers?
Re: are suspension torque specs the same [Re: mcmopars] #998856
05/24/11 08:05 PM
05/24/11 08:05 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
As John says, fastener torque relates to bolt size & thread pitch. Bolts actually tighten by stretching, which causes interference at the threads. The exception is when you want the object being held to have some free play, such as spring eyes & shackles for drag cars; in that case, the low side of fastener torque allows those items to pivot more freely. For a street car, there's generally enough rubber squirming during use that free-play isn't really an issue.
