Page 1 of 3 1 2 3
WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! #998808
05/24/11 12:17 AM
05/24/11 12:17 AM
Tennessee
WyleECoyote Offline OP
Tennessee
1971 Charger Superbee w 383 - 69,xxx original mile engine.
NEW radiator.
New hoses.
New thermostat.
New water pump.
New coolant.
Original shroud.
Original fan.
No clutch fan - direct drive fan.
Two years ago (Sep 2009) - we made it 1,000 mile round trip to St. Louis for Monster Mopar Weekend. No cooling problems.
Come home and back in the hive the Bee goes. Drive it a time or two and then in Sep 2010 I drive it to work and on the way home, the temp gauge reaches "uncomfortable".... (YOU KNOW - that white mark on the temp gauge to the far right?)
Today I take it out for a drive (88 degrees outside) and this happens:
Going...
going...
going..
Gone...
Thermostat Housing:
Top of Radiator:
Bottom of Radiator:
WHY IS IT OVERHEATING WITH EVERYTHING "NEW"? (2 years old)
Help......
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: WyleECoyote] #998809
05/24/11 12:20 AM
05/24/11 12:20 AM
Stuck or partly stuck stat
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: RapidRobert] #998810
05/24/11 12:22 AM
05/24/11 12:22 AM
Seattle Wa
PowerWagonDude Offline
Seattle Wa
Bad fan clutch
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: PowerWagonDude] #998811
05/24/11 12:29 AM
05/24/11 12:29 AM
Tennessee
Tennessee
No clutch fan. Direct drive. Thank you for the comment.
Wile E. Coyote
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: WyleECoyote] #998812
05/24/11 12:34 AM
05/24/11 12:34 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Even though the water pump is new....is it any good?
Was the impeller pressed on the correct amount ?
And perhaps worth pulling the thermostat out and sticking it in boiling water (or close that is) to make sure it is opening, and opening fully...
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: WyleECoyote] #998813
05/24/11 12:37 AM
05/24/11 12:37 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
New hoses.
Does the lower hose have the spring in it to prevent it from collapsing from the pump suction?
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: WyleECoyote] #998814
05/24/11 12:40 AM
05/24/11 12:40 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Lean...
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: 1_WILD_RT] #998815
05/24/11 12:41 AM
05/24/11 12:41 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Lean...
Or timing ?
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: WyleECoyote] #998816
05/24/11 12:51 AM
05/24/11 12:51 AM
top-o-the world
RAMIT Offline
RAMIT  Offline
top-o-the world
air pocket in the block???
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: Alaskan_TA] #998817
05/24/11 12:53 AM
05/24/11 12:53 AM
Tennessee
Tennessee
I THINK (assume) good water pump.
Welded on impeller.
Spring in lower hose.
Wile E. Coyote
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: 1_WILD_RT] #998818
05/24/11 12:55 AM
05/24/11 12:55 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Lean...
Now of this were a Japanese car the proper response would be.... Rean..
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: OzHemi] #998819
05/24/11 12:55 AM
05/24/11 12:55 AM
Tennessee
Tennessee
Timing hasn't changed since the 1,000 mile trip to St. Louis. Runs like a scaled dog - no valve chatter - real powerhouse! Starts with the touch of the key hot or cold.
Wile E. Coyote
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: WyleECoyote] #998820
05/24/11 01:00 AM
05/24/11 01:00 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
if you don't have leaks
then something almost has to be restricting flow
start simple at the thermostat
i would check or replace that first
the rad could of gottin clogged by crud left in the engine
flushing it would be my next move
let it run and watch it over heat
is the rad cap any good?
clues will stick out if you are observant
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: 1_WILD_RT] #998821
05/24/11 01:01 AM
05/24/11 01:01 AM
Tennessee
Tennessee
Lean...
Ha ha! Very funny to me! My first wife (1 of 4) is Korean. I was stationed there in Korea for 3 years. I always told the lady's my name was "Earl".........
They would try to repeat it as ELLR - or ELRL - or ELLL - they would get SOOO tongue tied!!
ANYWAYS... (back from memory lane...) I still have a dang hot Bee!!! WHY?????
Wile E. Coyote
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: flypaper] #998822
05/24/11 01:07 AM
05/24/11 01:07 AM
Tennessee
Tennessee
I rented the pressure test kit thingy from Advance Auto. System pressure tested to 17lbs and held for 2 hours. Radiator cap passed at 17lbs.
I have not tried flushing to see if crud came from engine. GREAT idea and watch it overheat. WILL do tomorrow. THANK YOU!
Wile E. Coyote
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: WyleECoyote] #998823
05/24/11 02:00 AM
05/24/11 02:00 AM
hooziewhatsit Offline
Remove the radiator cap and let it warm up. You should see a LOT of water moving through the radiator when the thermostat opens. If you don't see much water moving, it's likely your stat isn't opening.
DAMHIK
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: WyleECoyote] #998824
05/24/11 02:50 AM
05/24/11 02:50 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Theres a 33 degree difference of temp after passing through the radiator, so it appears that the radiator is doing its job.
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: Kern Dog] #998825
05/24/11 06:14 AM
05/24/11 06:14 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
What kinda stat are you using? What temperature? Just because its new doesnt mean it works. I bought the Napa Premium as well as the MOROSO / Mr. Gasket type. Both 160º. I bench tested them both and the NAPA opened at 157º and full port at 165º. The MOROSO/Mr. G style began to open at 172º and was full port by 185º...You can't trust any of them really.
I paid $12 for one 10 years ago and my engine was hitting 170º all day along in traffic and the freeway. 22" 4-core Radiator + Shroud, High Volume Water pump (cast iron), 7 blade fan + Hayden clutch. All timed and dialed in. 10:1.
I can't seem to find a decent stat anymore. She runs close to 185º all day now (given I am in a different region of the world but the weather is the same)
A trick I used to do on my Slant 6 Dart was open three 1/8" holes in a triangular formation on the surrounding area of the stat, chamfer the holes on both sides. My dart was riding 180º all day with a 180º Stant Stat
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: hooziewhatsit] #998826
05/24/11 08:51 AM
05/24/11 08:51 AM
Tennessee
Tennessee
DAMHIK
I'll give this a try at lunch time! Thanks for the idea.
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: Pyper70] #998827
05/24/11 08:56 AM
05/24/11 08:56 AM
Tennessee
Tennessee
I'll do what hoozie suggested and check the flow in the radiator. If I have no flow, out comes the thermostat, I'll bench test it AGAIN and WHATEVER goes back in (another new one or the current one that works) WILL have 3 holes in it! What size holes? 1/8th inch?
Wile E. Coyote
Page 1 of 3 1 2 3
