new gas gauge question #998718
05/23/11 10:04 PM
05/23/11 10:04 PM
ca, slo.
P
paulyvault Offline OP
P
ca, slo.
ok so i replaced the stock gauge in my 69 charger with a new autometer phantom gas gauge and when the tank is full it only reads 1/4 then it drops to E quick. any suggestions? help
Re: new gas gauge question [Re: paulyvault] #998719
05/23/11 10:26 PM
05/23/11 10:26 PM
Was it acting the same w the orig gauge? Sounds like a (tank) sending unit prob
Re: new gas gauge question [Re: paulyvault] #998720
05/23/11 10:26 PM
05/23/11 10:26 PM
Kansas
Screamingdemon Offline
Kansas
sounds like an electrical issue, check all your cables and make sure nothings grounding out on you.
Re: new gas gauge question [Re: Screamingdemon] #998721
05/23/11 11:38 PM
05/23/11 11:38 PM
IN
ahy Offline
ahy  Offline
IN
Autometer makes gauges in various specs to match different manufacturers (ohm rating empty and full). As a start, what is your guage rated? MOPAR is +/- 10 ohms full and around 78 empty. I can't find the exact specs in my FSM right now but this should get you in the ballpark.
Corrected "empty" ohms. link attached
https://board.moparts.org/ubbthreads/show...rue#Post6511431
Re: new gas gauge question [Re: ahy] #998722
05/24/11 02:15 AM
05/24/11 02:15 AM
ca, slo.
P
P
ca, slo.
how might i correct an ohm situation if i am high or low?
Re: new gas gauge question [Re: paulyvault] #998723
05/24/11 06:49 PM
05/24/11 06:49 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Buy the correct guage.
