Re: 3.3 water pump ?
[Re: BeEtLeJuIcE !]
#998655
05/24/11 11:51 PM
05/24/11 11:51 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Real easy to do, no special tools required for the serp belt, they are available and can make it just a tad easier but definately not a "need".
[Re: BeEtLeJuIcE !]
#998659
05/25/11 01:38 PM
05/25/11 01:38 PM
Posts: 2,928 A tad North of Indy
Blown71X
super gas
super gas
A tad North of Indy
Hay Rick .. would a 1/2" breaker-bar fit on the tensioner ? Also ... I hear that the pass side motor mount should be uNconnected ...and the motor dropped down slightly ... ??
Doubtfull on the breaker bar, unless it is real thin..You only have maybe a inch in that area.
I`m cheap so rather than buy the trick ratcheting ones, I made my own out of 1/2 square stock and a piece of 3/16 x 1" flat stock.
I personally don`t take the mount loose..that is taking WAY more off than needed...I never even open the hood until I refill it.
Rick
[Re: Blown71X]
#998660
05/25/11 01:44 PM
05/25/11 01:44 PM
Posts: 1,377 Ohio
Todd
Ohio
[Re: BeEtLeJuIcE !]
#998662
05/25/11 02:19 PM
05/25/11 02:19 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
What I am trying to do is get all my ducks in row before I start on this minor project.
regardless of what you have heard, you'll never be able to get ALL the ducks lined up. very short attention spans and when you herd them on one side, they scatter to the other
[Re: BeEtLeJuIcE !]
#998665
05/25/11 03:36 PM
05/25/11 03:36 PM
HotRodDave
Kalispell Mt.
I use the wrench method, a thin breaker bar can also be used, tight fit but I have one I got from GM good wrench that works, barely, I would imagine it could be imposible with the motor or sheet metal slightly shifted either direction. Warranty time is 1.5 hours. I don't know enough about the quality of different aftermarket brands to say if AZ has a good one or not, they all change vendors and re-builders so fast it is hard to say what you will get. I would just get the cheapest NEW pump I could find unless the price differance was HUGE then I would get a lifetime reman Chilton and haynes both suck!
[Re: BeEtLeJuIcE !]
#998668
05/26/11 09:32 AM
05/26/11 09:32 AM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
Doc the pump I got from Advanced had a Mopar sticker on it.It was a new one.Ive had a few on the bolts stuck.I just work them back and forth real easy with some good penatrating oil sprayed on them.They always come out with some paitiance.I always use antisieze when I reinstall them.I always get a new pump when I replace them.For the little they cost remans arent worth it.Rocky
Chrysler Firepower
[Re: Magnumguy]
#998672
05/26/11 01:24 PM
05/26/11 01:24 PM
Blown71X
super gas
super gas
A tad North of Indy
Not sure if this helps, I changed one on a 3.3 in our Dynasty, it was one of the easier pumps, time-wise, to do. My first east-west pump change and it went well.
Unfortunally this doesn`t count in this case, After 2000 they moved the pump to the rear (or right for you north/south guys) and with it being right next to the frame rail it adds a level of difficulty....The old front mounts were a piece of cake
Rick
