505" six pack engine WOT "bog"
#998453
05/23/11 04:57 PM
05/23/11 04:57 PM
Posts: 1,132 Home of the Bluegrass
MoparJunkie
Hey guys I have as stated a 505" 440 source strker kit with an Engle solid cam 587/602" lift eddy heads... Car runs good except on a WOT stomp I get a slight "bog" then it comes into power. I noticed I have 9" of vacuum at idle and my power valve is a 35. And my jets are 64's. The throttle plate is not past the transition slot and they have been drilled for more air... My question is should my PV be around a 55-65? And would that cause my "bog"?
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: 505" six pack engine WOT "bog"
[Re: MoparJunkie]
#998454
05/23/11 05:00 PM
05/23/11 05:00 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
it would help. a 50cc pump will help also
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#998455
05/23/11 05:07 PM
05/23/11 05:07 PM
MoparJunkie
Are those 50cc pump readily available.. And I'm assuming you're talking accelerator pump???? Correct? Also is there a number on my pump to tell me what I have?
[Re: MoparJunkie]
#998456
05/23/11 05:21 PM
05/23/11 05:21 PM
sixpackgut
Charleston
http://www.jegs.com/p/Holley/Holley-Hi-Performance-50cc-Accelerator-Pump-Kit/743667/10002/-1If you are getting a bog just driving the car, it will fall flat on its face if you take it to the track and actually hook. you will need a 35 squirter if you change pumps. if you can find a blue pump cam, it will help your current situation
[Re: MoparJunkie]
#998459
05/23/11 05:34 PM
05/23/11 05:34 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
How do you have your timing set-up; what's your initial, how much mechanical advance, what's your total and are you running vacuum advance?
Do you have any vacuum leaks anywhere? How have you verified it?
There are some excellent vacuum outboard sixpack carb set-up instructions on this site. Have you followed them carefully?
Perhaps someone can post the link to them.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#998460
05/23/11 06:08 PM
05/23/11 06:08 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
We have built several sixpac strokers and had the same problem. We found that the end carbs come in too fast and since they do not have acc pumps hence the bogg. We have had to sometimes double the springs in the diaphrams to cure that. It has never been the acc pump.
JAKES AUTOMOTIVE
[Re: sixpackgut]
#998462
05/23/11 08:18 PM
05/23/11 08:18 PM
MoparJunkie
Where can I get a blue pump cam? I take it that the blue has a more aggressive pitch to add more fuel?
[Re: MoparJunkie]
#998463
05/23/11 08:35 PM
05/23/11 08:35 PM
sixpackgut
Charleston
yes. thats correct. you can buy pump cam kits but you get a bunch. you maybe able to buy singles from ebay
http://shop.ebay.com/i.html?_kw=blue&_kw=holley&_kw=pump&_kw=cam
[Re: JAKE68]
#998464
05/23/11 09:08 PM
05/23/11 09:08 PM
Posts: 1,946 Connecticut
5126brl No more
Connecticut
Jake as someone with a 600 hp 451 with a Sixpac I would like to hear some more about your spring setups on these. Mine will still come in hard with the brown springs, running about 13" vacum at 1100rpm. installed quick fuel plates and 88 jets.
[Re: JAKE68]
#998465
05/23/11 09:17 PM
05/23/11 09:17 PM
MoparJunkie
Do I just use two springs on the diaphragm then???
[Re: MoparJunkie]
#998466
05/23/11 11:59 PM
05/23/11 11:59 PM
Posts: 43,233 Bend,OR USA
Cab_Burge
I agree with Jake, try slowing down the outbaord carbs opening rate first BTW what jetting and timing are you using now? Stock carbs or the newer Holley replacement carbs? I used the old(1984 maybe) Mopar bible suggestions on one of my sixpak carbs set up and used a wide ban on another set, 12.8 to 13.3 at WOT worked the best on both using 93 octane non Ethanol Oregon pump gas What type trans, automatic or stick? If automatic what stall converter? Enough questions from me now
[Re: Cab_Burge]
#998467
05/24/11 12:37 AM
05/24/11 12:37 AM
Posts: 10 Saskatoon, Canada
sk68gtx
Saskatoon, Canada
I haven't checked lately, but you used to be able to buy spring kits with varying strengths for the end carbs. We used them for tuning along with jets / plates, squirters and timing based upon air and track conditions.
68 GTX 440-6
10.92 @ 120
03 CTD Laramie QC 4x4
[Re: gch]
#998471
05/24/11 09:28 AM
05/24/11 09:28 AM
JAKE68
Shelby mi.
Try putting on some end carbs with accelerator pumps.Might wake it up for ya.
That will cover up the problem that the end carbs are opening too fast. They do make a spring kit, but occasionlly I still can't get them to slow down enough with even the heaviest springs that is why I would have to double the light springs to to tune it in. I never tried the idea with a hole in the vacuum line but I like that I may have to try it. It use to work when I was playing with the vacuum line on a turbo car I had.
JAKES AUTOMOTIVE
