383 whistles ???? #998343
05/23/11 01:48 PM
05/23/11 01:48 PM
ohio
flynbyu Offline OP
flynbyu  Offline OP
ohio
Hi all ... I have an all stock 69 383 that will whistle around 1/4 throttle.I have put 3 different carbs on it (2 holleys and 1 edelbrock) with 1/2 inch spacer and it will still whistle. If I back out of it or give it more it goes away... is it the intake ? whatcha think ? thanks
Re: 383 whistles ???? [Re: flynbyu] #998344
05/23/11 01:56 PM
05/23/11 01:56 PM
North Central Florida
E
eightlitermopar Offline
E
I had a 383 do that too, I just thought it was the carter carb.
If you have changed out your carbs, I dunno
Maybe put a 4 hole spacer on it to mix up the air flow a little and see what happens?
eight
Mopar or no car
Re: 383 whistles ???? [Re: eightlitermopar] #998345
05/23/11 04:09 PM
05/23/11 04:09 PM
Can you ID it maybe w a stethoscope if you can get that same amt of load (1/4 throttle) in your driveway & maight have to jack up the rear & put it in gear to load it. Might b able to hear it there w the hood opened
Re: 383 whistles ???? [Re: RapidRobert] #998346
05/23/11 05:13 PM
05/23/11 05:13 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
You can spray water around the base of the cab (spray bottle) and see if the whistle changes or goes away.
If it does you've got a vacuum leak at the carb base.
I've seen some carbs have vacuum ports exposed to the air causing a whistle and leaks
Re: 383 whistles ???? [Re: SNK-EYZ] #998347
05/23/11 07:07 PM
05/23/11 07:07 PM
Royersford, PA
bschargerse Offline
bschargerse  Offline
Royersford, PA
I had the same problem on my Newport. Whistled while driving with an Edelbrock and a Holley carb. Does not whistle with the Carter AVS. I can't figure it out. And it only whistles while driving.
Brian - 1971 Dodge Challenger
"The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
Re: 383 whistles ???? [Re: flynbyu] #998348
05/23/11 08:48 PM
05/23/11 08:48 PM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
Are you using a PCV valve?
Re: 383 whistles ???? [Re: jb500] #998349
05/24/11 12:30 AM
05/24/11 12:30 AM
ohio
flynbyu Offline OP
flynbyu  Offline OP
ohio
Heres the update .....After I posted ...eightlitermopar posted try a four hole spacer ..... thought to myself how hard could it be to make one out of wood...found a slab of 3/4 inch in the garage,used the 4 hole gasket as a template .... 15 minutes and done .....The whistle is gone and no more flat spot .... thanks again ......
Re: 383 whistles ???? [Re: flynbyu] #998350
05/24/11 12:34 AM
05/24/11 12:34 AM
must have had a slight vac leak, have you took it out & noticed if it runs any different/better
Re: 383 whistles ???? [Re: RapidRobert] #998351
05/24/11 12:48 AM
05/24/11 12:48 AM
ohio
flynbyu Offline OP
flynbyu  Offline OP
ohio
There is no vac leak... when I put the carb on the motor all gaskets were new...and also tried numerous times to find a vac leak(carb cleaner,spray water,propane).. .and the carb just came off my dads Lil Red and ran fine with no whistle,not to mention the other 2 carbs that had the same whistle ..... 4 hole spacer str8ened the air flow in the intake ...I have a thermoquad Im gonna try with no spacer and see what happens ...just for giggles...
Re: 383 whistles ???? [Re: flynbyu] #998352
05/24/11 01:07 AM
05/24/11 01:07 AM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
maybe it's just happy?
