Re: 383 whistles ????
[Re: flynbyu]
#998344
05/23/11 01:56 PM
05/23/11 01:56 PM
Posts: 1,630 North Central Florida
eightlitermopar
I had a 383 do that too, I just thought it was the carter carb. If you have changed out your carbs, I dunno Maybe put a 4 hole spacer on it to mix up the air flow a little and see what happens? eight
Mopar or no car
[Re: eightlitermopar]
#998345
05/23/11 04:09 PM
05/23/11 04:09 PM
RapidRobert
Can you ID it maybe w a stethoscope if you can get that same amt of load (1/4 throttle) in your driveway & maight have to jack up the rear & put it in gear to load it. Might b able to hear it there w the hood opened
[Re: RapidRobert]
#998346
05/23/11 05:13 PM
05/23/11 05:13 PM
Posts: 10,124 A Red State
SNK-EYZ
A Red State
You can spray water around the base of the cab (spray bottle) and see if the whistle changes or goes away. If it does you've got a vacuum leak at the carb base.
I've seen some carbs have vacuum ports exposed to the air causing a whistle and leaks
[Re: SNK-EYZ]
#998347
05/23/11 07:07 PM
05/23/11 07:07 PM
Posts: 2,507 Royersford, PA
bschargerse
Royersford, PA
I had the same problem on my Newport. Whistled while driving with an Edelbrock and a Holley carb. Does not whistle with the Carter AVS. I can't figure it out. And it only whistles while driving.
Brian - 1971 Dodge Challenger "The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
[Re: jb500]
#998349
05/24/11 12:30 AM
05/24/11 12:30 AM
Posts: 80 ohio
flynbyu
ohio
Heres the update .....After I posted ...eightlitermopar posted try a four hole spacer ..... thought to myself how hard could it be to make one out of wood...found a slab of 3/4 inch in the garage,used the 4 hole gasket as a template .... 15 minutes and done .....The whistle is gone and no more flat spot .... thanks again ......
[Re: flynbyu]
#998350
05/24/11 12:34 AM
05/24/11 12:34 AM
RapidRobert
must have had a slight vac leak, have you took it out & noticed if it runs any different/better
