Header Bolt Question SBM #998303
05/23/11 11:44 AM
05/23/11 11:44 AM
Circleville, Ohio
E
Evil67 Offline OP
Evil67  Offline OP
E
Circleville, Ohio
NEVER worked on a small block before - do header bolts go into water jacket????
Former Username - 71Cuda
Current Ride: 1967 Dart - 340
Re: Header Bolt Question SBM [Re: Evil67] #998304
05/23/11 11:46 AM
05/23/11 11:46 AM
NY usa
540challenger Offline
NY usa
oops, i had to edited sorry. Magnum are dry LA i am having a brain fart right now and can't remember I think they are also dry someelse will chime in
Re: Header Bolt Question SBM [Re: Evil67] #998305
05/23/11 11:47 AM
05/23/11 11:47 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
On OEM heads,(LA) end bolt holes only.
Re: Header Bolt Question SBM [Re: 540challenger] #998306
05/23/11 11:49 AM
05/23/11 11:49 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Factory iron LA heads go into water jackets,most aftermarket heads are dry.
Re: Header Bolt Question SBM [Re: S/ST 3040] #998307
05/23/11 11:49 AM
05/23/11 11:49 AM
Circleville, Ohio
E
Evil67 Offline OP
Evil67  Offline OP
E
Circleville, Ohio
My combo is a 340 TA Block and W2 heads.....
Re: Header Bolt Question SBM [Re: Evil67] #998308
05/23/11 12:05 PM
05/23/11 12:05 PM
S/ST 3040 Offline
S/ST 3040  Offline
If you have W-2 heads with freeze plugs in the end, they probably go into water too.
I'm pretty sure later W-2 heads are dry.
Re: Header Bolt Question SBM [Re: S/ST 3040] #998309
05/23/11 12:57 PM
05/23/11 12:57 PM
Circleville, Ohio
E
Evil67 Offline OP
Evil67  Offline OP
E
Circleville, Ohio
Thanks -I will check.
Re: Header Bolt Question SBM [Re: Evil67] #998310
05/23/11 01:15 PM
05/23/11 01:15 PM
South Lyon, Michigan
6bblRoadrunner Offline
Just ran into this on mine...W2's with freeze plugs. End bolts do go into water.
Re: Header Bolt Question SBM [Re: 6bblRoadrunner] #998311
05/23/11 01:51 PM
05/23/11 01:51 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I have an old set of W2s and they do not go into the water!!
Re: Header Bolt Question SBM [Re: Blucuda413] #998312
05/23/11 02:01 PM
05/23/11 02:01 PM
Circleville, Ohio
E
Evil67 Offline OP
Evil67  Offline OP
E
Circleville, Ohio
Mine have freeze plugs.....
