Re: Wifee's new 2011 Charger DOA
[Re: Mr.Yuck]
#998204
05/23/11 10:17 AM
05/23/11 10:17 AM
Posts: 15,996 RI Deep in the rust belt
chargervert
My wife killed our new Challenger R/T last year by accidently hitting the trunk realease button on the key fob. The trunk light stays on,the battery was dead. The first thing I noticed when I went to take the car out,was that the trunk was popped open,so like a dope I closed it. I had to climb through the back seat and manually pop the trunk to get at the battery. I charged it overnight,and its been fine ever since.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: chargervert]
#998206
05/23/11 10:42 AM
05/23/11 10:42 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
why can't you open the trunk w/ a key????
[Re: 52savoy]
#998207
05/23/11 10:44 AM
05/23/11 10:44 AM
Posts: 322 Itasca, Texas
Mad_Scientist
Itasca, Texas
That happened to my Challenger too. It was the battery. Just put it on a charger and it will start up and be fine.
69 Super Bee 440 5-speed 70 Dart Swinger 340 4-speed 69 Camaro SS 396 4-speed 66 Cutlass Convertilbe 70 Judge Ram Air III 4-speed 68 F-100 SWB
[Re: Mr.Yuck]
#998208
05/23/11 10:44 AM
05/23/11 10:44 AM
chargervert
There is no external lock for the trunk on a new Challenger.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: Todd]
#998210
05/23/11 01:36 PM
05/23/11 01:36 PM
chargervert
I had to go through the back seat to get at the battery,because the nose was pointed in the garage.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#998211
05/23/11 03:05 PM
05/23/11 03:05 PM
Posts: 1,377 Ohio
Todd
Ohio
Cables too short Huh? I hate when that happens.
[Re: Todd]
#998212
05/23/11 05:21 PM
05/23/11 05:21 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
It happened to mine about a month ago. Somebody hit the trunk button. Battery was dead. I saw that the trunk was open, when I walked up to it. I closed the trunk, and then tryed to start it. Dead battery.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: Mr.Yuck]
#998215
05/24/11 12:02 AM
05/24/11 12:02 AM
Posts: 4,253 State of Fascism
52savoy
State of Fascism
Yeah..I thought they should send a mechanic out too. Called Chrysler and they flat bedded it back to the dealer. They put the charger on it using the post under the hood. They checked around and found nothing. Mentioned the ACC(switch) might not have turned off when my wife left the car and the systems didn't shut down. We'll see... also...The brakes have always felt like your driving on rumble strips whenever they are applied. Had them checked again(2nd time). Need rotors on all four corners. I looked at the rotors when we got the car home and they are hosed... At this point were ready for a buy back.
[Re: quick77rt ]
#998217
05/25/11 08:48 AM
05/25/11 08:48 AM
Posts: 5,337 the house on the left.
cogen80
at three weeks old? holy crap.
[Re: cogen80]
#998218
05/25/11 10:25 AM
05/25/11 10:25 AM
Posts: 1,397 Charleston, South Carolina
67RT
I've had mine back to the dealership a couple times so far. First one of the keys was not programmed when I got the car. I had that corrected within a couple days of purchasing. Then I started getting a warning on the dash "Service Keyless System" I thought it was related to the key not being programmed correctly. I figured I would let it go until the first oil change.
Next issue was a check engine light and traction control light that came on when I started the car, also sounded like there was no oil for a second or two, just kind of clattery sounding. I took it in for the lights and they found an issue with the camshaft position sensor. I don't think they actually replaced any parts, just reflashed the computer. I also had them check out the keyless issue and that turned out to be a bad door handle.
While waiting a week for the door handle to come in, I still had the engine light on and the noise at start up once in a while. The door handle came in so when I made my service appointment, I told them they needed to check the light again. My appt was on Monday, so I dropped the car off Sunday afternoon. Well when I went to start the car, the car was pretty much dead. It had enough juice to unlock the doors and one feeble starting attempt and that was it. I ended up jump starting it to get it running. The dealer did not find anything electrical wrong with the car and they could not re-check the codes for the check engine light because they said they were wiped out when the battery went dead.
So far everything has been good, but it has only been about 3 weeks since everythings been fixed. But I think there may be something loose or flapping under the car. I can sometimes hear a noise at around 60mph, but it is hard for me to pinpoint where it is coming from. If I roll down the window, the wind noise is too loud. Plus the road I drive to work is not the smoothest asphalt so I get some tire noise too, my car has the 20" wheels. I just need to get under it and see if there is anything loose.
But overall, I do like the car a lot. I think it drives great and I really like the features. Hopefully the issues I have are just part of getting the bugs out of the new model.
1968 Fury III Convertible - 383 4bbl - 4-speed - Black - SOLD and going down under.
1967 Coronet R/T - 440 - 4-speed - Dana 60 - Red - FOR SALE
