car running rough #998101
05/22/11 11:09 PM
05/22/11 11:09 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
okay i was on the freeway & then there was a real bad noise sounded like a tinny like sound real loud for only a few seconds then went away .thought motor blew pulled over no noise motor sounds fine but runs very bad like choke is stuck or plugged up jet in carb . but no black out the back starts fine I drove it 40 miles after this . It just runs like crap. Maybe jumped time took a valve ??? what do you guys think? It is a small block built 360 electronic ign. p.s .car will still smoke tires but will not idle very well & seems like it is fighting to run I did change carb out same thing. any ideas????
Re: car running rough [Re: AB&E] #998102
05/22/11 11:19 PM
05/22/11 11:19 PM
any ideas?
on a tim ch check: see what it's timed at (initial), check idling vacuum, put timing marks on TDC & see if the rotor is on/close to #1 or #6. Holler back
Re: car running rough [Re: AB&E] #998103
05/23/11 12:04 AM
05/23/11 12:04 AM
hobbs, new mexico
SixDRacing Offline
SixDRacing  Offline
hobbs, new mexico
first is to run a compression test on all cylinders.
Re: car running rough [Re: SixDRacing] #998104
05/23/11 12:12 AM
05/23/11 12:12 AM
washington
AB&E Offline OP
AB&E  Offline OP
washington
I have been looking for a reason to toss this motor as I do not want to work on it .so with what i have told you guys at this point is it poss. that is a low voltage prob to dist or maybe just my repop mopar wires i know you all said to do the timing &compression but its sunday & yah. so just bench tech tonight
Re: car running rough [Re: AB&E] #998105
05/23/11 12:16 AM
05/23/11 12:16 AM
Inquiring minds wanna know esp something that dramatic. On an energetic day let us know what you find.
Re: car running rough [Re: RapidRobert] #998106
05/23/11 08:24 PM
05/23/11 08:24 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
okay its a new day pulled pass valve cover off seems that I have put a pushrod through the rocker arm It did not realy click much just faintly. so I guess I must of over reved
can you tell me if any small block rocker arm &pushrod is the same oh yah I bent the push rod also I have a 360 motor stock heads just shaved &ported I have been trying to blow it up so I can use my bigblock
thanks abe
Re: car running rough [Re: AB&E] #998107
05/23/11 09:25 PM
05/23/11 09:25 PM
Abe you sound pumped! Yes all SB rocker arms/p rods (318/360 HYD) are the same
