As long as you limit the travel of the engine with a torque strap or chain most rubber mounts should work.
I had some issues with a set of MityMounts from Dynatech, and they quickly replaced them with the correct ones. Apperantly a few bad sets got out early on in production, but they have corrected that now. The replacements fit like the factory ones. You can't really tell the difference between them and stock ones when they're installed.
They require no additional engine restraining devices, as they are self limiting. I like them because they look stock, allow the engine to shake(Shaker hood), bolt right in and are very strong.
http://www.mitymounts.com/chrysler.htm
