Re: "308" Heads what to ask for
[Re: Posest]
#99753
08/04/08 06:22 PM
08/04/08 06:22 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
89-92 360 had 308 heads. Trucks and Vans.
Some 308s have the number cast on top of the runner and some have it cast under the runner. The easiest way to identify them if the number is not on top of an intake runner is to look at the port size, they are the same size as any other 360 port opening, if they are indeed 360 heads look for a roller cam, 308s are the only heads on roller cam 360s because the pushrod hole is drilled quite a bit bigger in them than normal 360 heads, that hole is the only other way to identify them if they are bolted on and no cam to look at, other wise you got to pull them to see. You should not buy some with out pulling them first because a lot of them crack.
[Re: Posest]
#99756
08/05/08 07:50 AM
08/05/08 07:50 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
if you get maggies complete with the rocker gear, all you need are different pushrods & lifters (maybe even not lifters if you have an aftermarket cam), and intake (or redrill the heads to LA intake bolt pattern). if you go with new aftermarket magnums (enginequests 318A's & 318B's) get the B's, as they're drilled to LA intake pattern. do a search in the "best of" tech archives for magnum conversion for more info.
if looking for 308's, as hotroddave said, look for a TBI injected 360, most likely to be found in 3/4 and 1 ton trucks and vans.
[Re: patrick]
#99757
08/05/08 11:50 AM
08/05/08 11:50 AM
Posts: 711 Montana
Posest
Montana
