Difference btwn '68 vs '69 B-bdy dash wiring harnesses? #997408
05/22/11 11:32 AM
05/22/11 11:32 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
The illustrations for M&H '68 and '69 under dash wiring harnesses for B-body Plymouth with oil pressure light appear to be different and so is the price. Does anyone know the differences between the two (it's obvious that the '69 is more complex, at least the images are) and could I use a '68 wiring harness from a '68 Road Runner on a '69 GTX with oil pressure light?
Part # Description Price Add to Cart
HU268B Dash harness, 1968 Plymouth and Dodge B-body models with oil light, reproduction. $549.00
'68
HU271B Dash harness, 1969 Plymouth and Dodge B-body models with oil light, reproduction. $499.00
'69
Re: Difference btwn '68 vs '69 B-bdy dash wiring harnesses? [Re: A12] #997409
05/22/11 11:46 AM
05/22/11 11:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Something in the ignition switch wiring , I think there is a ground wire in the 69 harness that is not in the 68 , plus the 69 is more expensive because it fits an A12 also
Re: Difference btwn '68 vs '69 B-bdy dash wiring harnesses? [Re: A12] #997410
05/22/11 08:37 PM
05/22/11 08:37 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
i also think there may be a difference in refernce to the console wiring hookup/plug
Re: Difference btwn '68 vs '69 B-bdy dash wiring harnesses? [Re: TONY_DAGOSTINO] #997411
05/22/11 09:35 PM
05/22/11 09:35 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Thanks John and Tony, now I'm thinking the wiring harness I have is from a '69 road runner......and my GTX does have a console and a 4-speed so how do I tell which year wiring harness I have Can I tell by the ignition switch connection...thanks.
MikeR
Re: Difference btwn '68 vs '69 B-bdy dash wiring harnesses? [Re: A12] #997412
05/22/11 10:47 PM
05/22/11 10:47 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Fuse box location is different if that matters
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Difference btwn '68 vs '69 B-bdy dash wiring harnesses? [Re: mopargem] #997413
05/23/11 02:26 AM
05/23/11 02:26 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
There is also some wires that lead out to the side markers on a 68 that a not used on 69.
Re: Difference btwn '68 vs '69 B-bdy dash wiring harnesses? [Re: mopargem] #997414
05/23/11 10:18 AM
05/23/11 10:18 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Fuse box is in the same basic location just accessed differently , underdash vs thru the open glove box.
The connector on the ignition switch is the same one has an extra wire the other does not going by memory when I owned both and stripped both .
Re: Difference btwn '68 vs '69 B-bdy dash wiring harnesses? [Re: JohnRR] #997415
05/23/11 03:04 PM
05/23/11 03:04 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
John, I checked the ignition switch connection/wiring on the harness that I have in hand at the moment (have another at home) to the wiring schematics here http://www.mymopar.com/downloads/1968/68BelvedereGTXSatelliteRoadRunnerA.JPG and here http://www.mymopar.com/downloads/1969/69BelvedereGTXSatelliteRoadRunnerA.JPG and there is no extra wire that I can see, only a different routing of the dark blue wire but still the same number of wires. Now the only thing that I can see that might denote a '68 from a '69 is that the list of circuits is alpha characters for the '68 and numerical for the '69 for the instrument lights, high beam indicator, temp gauge, gauge feed etc. (see the attached links to wiring diagrams. The under dash wiring harness I have has alpha characters and I'll check the one I have at home to see which characters it has......I hope numerical
Mike
Re: Difference btwn '68 vs '69 B-bdy dash wiring harnesses? [Re: A12] #997416
05/23/11 03:11 PM
05/23/11 03:11 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
This connection: (I think this is a '68 in alpha)
Re: Difference btwn '68 vs '69 B-bdy dash wiring harnesses? [Re: A12] #997417
05/23/11 03:12 PM
05/23/11 03:12 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
the other side..........
Re: Difference btwn '68 vs '69 B-bdy dash wiring harnesses? [Re: A12] #997418
05/24/11 02:49 PM
05/24/11 02:49 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Anyone have a known '69 B-body under dash wiring harness that can check if it has numeric characters on the instrument plug/connection. I can't get to my '69 GTX quick enough and hoping someone might have one out of the car......Tony you have one laying around you can check Thanks,
MikeR
This is out of a '68 road runner with letters:
Re: Difference btwn '68 vs '69 B-bdy dash wiring harnesses? [Re: A12] #997419
05/25/11 07:55 PM
05/25/11 07:55 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
MikeR
Anyone????
Re: Difference btwn '68 vs '69 B-bdy dash wiring harnesses? [Re: A12] #997420
05/25/11 08:16 PM
05/25/11 08:16 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Okay in the mean time: I've been comparing the '68 wiring harness to the '69 and one of the differences I found is the lack of a Yellow w/tracer wire from the "Light Switch" on the '69 connection at the switch.
Here is the wiring harness I have that DOESN'T HAVE THE YELLOW W/TRACER sitting on a '68 wiring schematic diagram that shows the yellow tracer? I'm starting to think I have a '69 wiring harness that I need
This Yellow w/tracer wire goes from the dash switch to the front running lights(turn signal) on the '68 and now I think I know why the front running lights go off when you put the headlights on the '68 (rr,sat..) but not on the '69's......
MikeR
Re: Difference btwn '68 vs '69 B-bdy dash wiring harnesses? [Re: A12] #997421
05/25/11 08:29 PM
05/25/11 08:29 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Okay what's this for on the fuse box side of the wiring harness...?
Re: Difference btwn '68 vs '69 B-bdy dash wiring harnesses? [Re: A12] #997422
05/25/11 08:31 PM
05/25/11 08:31 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
and these on the other end?
Re: Difference btwn '68 vs '69 B-bdy dash wiring harnesses? [Re: A12] #997423
05/26/11 12:43 AM
05/26/11 12:43 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I'm gonna say the yellows are for the door pillar switches, and that black wire is most likely the wire to the e-brake switch. I 'm sure that's the way my harness is on my 68 GTX.
Re: Difference btwn '68 vs '69 B-bdy dash wiring harnesses? [Re: superwrench] #997424
05/26/11 01:47 AM
05/26/11 01:47 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Those yellows are the dome light switches in the pillar.
Re: Difference btwn '68 vs '69 B-bdy dash wiring harnesses? [Re: JohnRR] #997425
05/26/11 11:40 AM
05/26/11 11:40 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Thanks Richard and JohnRR...the more I study the '68 and '69 wiring schematics the less I really find different but still need to keep digging The Yellow w/tracer at the light switch on the '68 harness and the side marker light wiring at the front (not the under dash harness but I need to trace that circuit down ) seems to be the only "telltales" of which harness is which.
Thanks again guys for the help
MikeR
Re: Difference btwn '68 vs '69 B-bdy dash wiring harnesses? [Re: A12] #997426
05/26/11 12:19 PM
05/26/11 12:19 PM
Utah
E
Eagleone1983 Offline
E
Utah
A12, I just wanted to comment on the passenger side door pillar dome light switch. On my Roadrunner, which has the light package, I have two yellow wires coming out of the plug and not really sure where they go. My harness was pretty hacked up as well. So I'm kind of going through what you are.
Re: Difference btwn '68 vs '69 B-bdy dash wiring harnesses? [Re: Eagleone1983] #997427
05/26/11 01:02 PM
05/26/11 01:02 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
What year? And I'm trying to figure out the console, map light, etc. The A01 light package would have had a glove box light, map light, time delay light at the ignition key switch, the console would have lights that went on when the doors open one on each side, then of course the fender top mounted "bullets" and the trunk light......
My GTX doesn't have the Light Package but I'd like too so I'm looking for what makes all of that work
I'll keep you guys informed with what I keep finding..
MikeR
