Re: Lifter noise- what now? Project creep problem!
[Re: radar]
#997182
05/22/11 01:49 AM
05/22/11 01:49 AM
RapidRobert
I'd check the preload on all of em & if good then push down on each one of them straight down on the p rod end of the rocker arm w a wooden hammer handle while idling & see if I could ID the bad one (the bad one will quiet some w the pressure on it) & replace it & rebreak in the cam procedure
