fuel expanding and leaking out gas cap..why? *DELETED* #997050
05/21/11 09:45 PM
05/21/11 09:45 PM
detroit,michigan
ctsuperbee Offline OP
detroit,michigan
Post deleted by ctsuperbee
Re: fuel expanding and leaking out gas cap..why? [Re: ctsuperbee] #997051
05/21/11 11:32 PM
05/21/11 11:32 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
needs to be vented I'm guessing.
Coming soon!!!!
Re: fuel expanding and leaking out gas cap..why? [Re: Mr.Yuck] #997052
05/21/11 11:34 PM
05/21/11 11:34 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
I had the same issues, although not as severe. I drilled two small holes in the cap, just inside the rubber seal. Seemed to take care of the issue.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: fuel expanding and leaking out gas cap..why? [Re: Mr.Yuck] #997053
05/22/11 11:50 AM
05/22/11 11:50 AM
crlush Offline
crlush  Offline
Re: fuel expanding and leaking out gas cap..why? [Re: ctsuperbee] #997054
05/22/11 12:25 PM
05/22/11 12:25 PM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
hi guys, both of my cars are doin the same thing.. my 70 charger after running engine and breaking in new cam and heating up engine. all the sudden the gas expanded in tank and came gushing up fuel neck and overflowing all over quarter panel and continued doin it til 15-20 min after car was shut off...why? also my 70 bee was just sitting in garage..sun beating on back end of car..after awhile fuel expanded built up pressure and started leaking out gas cap...im puzzled.please help moparts
hmph...what a conundrum!
There can only be one explanation:
You're car is running SO efficient, it actually produces fuel. You should think of getting a patent on that before big oil and a cabal of middle eastern sheik's hunt you down and bang you over the head w/ a 100mpg carburetor!
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: fuel expanding and leaking out gas cap..why? [Re: ctsuperbee] #997055
05/22/11 12:36 PM
05/22/11 12:36 PM
N
NITROUSN Offline
NITROUSN  Offline
N
There is a vent tube or at least there should be. Look there for the problem first.
Re: fuel vent hose is hooked up on the filler neck. *DELETED* [Re: NITROUSN] #997056
05/22/11 10:57 PM
05/22/11 10:57 PM
detroit,michigan
detroit,michigan
Re: fuel vent hose is hooked up on the filler neck. [Re: ctsuperbee] #997057
05/22/11 11:59 PM
05/22/11 11:59 PM
Alaska
73rrak Offline
73rrak  Offline
Alaska
Are you running a return line to the tank from a regulator or a fuel filter with the return line ? Check the vent on the cap and see if it's plugged. I had a vented stant cap that Stant didn't drill the vent hole all the way through.
Re: fuel expanding and leaking out gas cap..why? [Re: ctsuperbee] #997058
05/23/11 08:40 AM
05/23/11 08:40 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
It's doing that because you don't have the factory vents hooked up right. It didn't do that when the car was new. There no reason to alter factory fuel tank vent setups, I don't know why people love to do it? It causes nothing but trouble, there no advantage to changing it.
Re: fuel vent hose is hooked up on the filler neck. [Re: ctsuperbee] #997059
05/23/11 01:45 PM
05/23/11 01:45 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
I don't think the factory ever vented the fuel tank to the trunk. That would be very dangerous.
Re: fuel vent hose is hooked up on the filler neck. [Re: Steve340] #997060
05/23/11 01:59 PM
05/23/11 01:59 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
The vent on a charger runs out of the sending unit, thru the trunk (via the filler neck) and hooks up to the gas cap.
Here's an Idea. Run the car with the gas cap open and see what happends. If it still gushes then your sending unit port might be clogged.
Re: fuel vent hose is hooked up on the filler neck. *DELETED* [Re: Mr.Yuck] #997061
05/24/11 07:26 AM
05/24/11 07:26 AM
detroit,michigan
detroit,michigan
Re: fuel vent hose is hooked up on the filler neck. [Re: ctsuperbee] #997062
05/24/11 10:07 AM
05/24/11 10:07 AM
Cincinnati, Ohio
Cincinnati, Ohio
Not trying to be a smartass, but you can't vent the tank into the tank. So the vent line doesn't connect to the filler tube or the sending unit. It has to vent somewhere else. I'm not familer with your car but I am sure of what I said.
The second fittings on sending units are for fuel return if so equipped, not for venting.
Re: fuel vent hose is hooked up on the filler neck. [Re: Challenger 1] #997063
05/24/11 10:26 AM
05/24/11 10:26 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
sorry that is correct don't know what I was thinking,,,, the Charger vent tube runs from the top of the filler neck down thru the trunk.
Re: fuel vent hose is hooked up on the filler neck. [Re: Mr.Yuck] #997064
05/24/11 04:20 PM
05/24/11 04:20 PM
Make sure the mini vent tube at the top of the filler neck inside the trunk that goes down/thru the trunk floor is open/dont drill/alter the gas cap/dont fill the tank so high EDIT dont need a tank sending unit w the extra nipple unless you plan to add a return line from the carb which is a good idea (esp if vapor lock/overheating probs) but it will not help your situation
Re: fuel vent hose is hooked up on the filler neck. [Re: ctsuperbee] #997065
05/24/11 05:24 PM
05/24/11 05:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
thanks for the last replies, that helped. my sender doesnt have a vent port on it. i will search for a new one that has a vent on it. and hook it up to the factory vent tube on the filler neck. i thought the vent on the neck was all there was to it. i didnt know it went to the sender.these damn repop parts are never correct !!!
There is no vent tube on the sender, the tank has 2 vent lines on it , one connects to the line that goes thru the trunk the other connected to a small J shaped line that hangs on the shock crossmember.
Re: fuel vent hose is hooked up on the filler neck. *DELETED* [Re: JohnRR] #997066
05/25/11 06:55 AM
05/25/11 06:55 AM
detroit,michigan
detroit,michigan
Re: fuel vent hose is hooked up on the filler neck. [Re: ctsuperbee] #997067
05/25/11 07:15 AM
05/25/11 07:15 AM
Columbus Ohio
mopfried Offline
mopfried  Offline
Columbus Ohio
My honda did that and I finally changed the cap and the problem was gone.
Re: fuel vent hose is hooked up on the filler neck. [Re: mopfried] #997068
05/25/11 09:48 AM
05/25/11 09:48 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
can't change the cap on a Charger like that. The vent is allll the way up at the top of the filler neck. Have you blown out the line w/ some air? might have some junk trapped in it. Also did you open the cap and run the car?
Re: fuel vent hose is hooked up on the filler neck. *DELETED* [Re: Mr.Yuck] #997069
05/26/11 10:10 PM
05/26/11 10:10 PM
detroit,michigan
detroit,michigan
