Re: Putting heads on a 440 ??????
[Re: GreenGlow]
#996885
05/21/11 08:24 PM
05/21/11 08:24 PM
RapidRobert
It's fine to reuse bolts & I'm surprised 70 started to twist one. Steel shim gaskets (like OE) will of course give you a slightly higher CR but they to a certain extent require flat surfaces (head/deck) & using spray Permatex copper coat or quality alum spray paint works good w them. The felpro (or other brands) composition thicker gaskets seal better on a non perfect surface(s). Might chase the threads w a "thread chasing" tap which is diff from a regular thread cutting tap (& they're cheap) and I wet threads w 30 wt eng oil then blow them off w shop air. Holler back
[Re: GreenGlow]
#996891
05/22/11 12:09 AM
05/22/11 12:09 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
I used aviation sealer on the threads as I always have and a drop of oil under the head on the bolt before putting it in. Maybe the motor was built with a bad set of bolts. I've never had this problem before and I did everything the same. Could this be the start of the end of the world ?? hahhahahaha
All the early(1951 to 1999 or when the 3G hemi came out) Mopar V8 had blind head bolt holes, no sealer needed on any of the head bolts. I use oil (sparingly, coat all the threads lightly )and then torque them in three steps, 25, 50 and then 65 ft. lbs I have had some of the stock 426 Hemi longer head bolts start to stretch and then had to buy some new ones to get the motor together, never a BB or SB or early Hemi Try oil only and see if that works okay for you
[Re: RapidRobert]
#996893
05/22/11 08:07 AM
05/22/11 08:07 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
I agree just oil or ARP lube on the bolts.If I read this right you had 2 bolts in the same hole that did the same thing?If so you have a problem with that hole.One bolt might stretch but I doubt 2 would.Only thing that would cause that problem would be the hole.Rocky
Chrysler Firepower
[Re: therocks]
#996894
05/22/11 09:01 AM
05/22/11 09:01 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Never had one stretch before, but I will generally use new ones.
Rocky, I see your point but I am interested in how a hole could make a bolt stretch.
Careful, your character's showing!
[Re: mopar346]
#996895
05/22/11 09:06 AM
05/22/11 09:06 AM
therocks
Niles , Ohio
If the bolt is bottoming out in the hole it will start to twist and stretch.Thats the only reason I can see.I can see one bolt being bad but if it was seated in another hole and was Ok and it stretched in that hole it has to be the hole.Last set of MP bolts I bought was about 15 bucks.Now I run ARPs.Rocky
Chrysler Firepower
[Re: therocks]
#996896
05/22/11 09:44 AM
05/22/11 09:44 AM
mopar346
Got it, the twist and stretch I see, was jsut having difficulty with a straight stretch from a hole. Yea new bolts are cheap enough and always chase the hole before assembly. Thanks, Kevin
