Re: XE262 cam degreeing for 4x4
[Re: goldmember]
#996854
05/21/11 08:14 PM
05/21/11 08:14 PM
RapidRobert
If you have a multiple keyway tim set might adv it 4 deg then degree it. (as you know) it'll give you the most low end and give you practice in degreeing (if you want/need practice) and you'll have the #'s generated down on paper & know that nothing has been left to chance (incl V/P clearance) and I'm assuming that you have the fuel to support the DCR you'll end up w? THEN w that finalized work on dialing in the dist one (sub) system at a time/IN ORDER: Initial/total/springs/vac adv. Then the carb (but you do want the main metering roughly correct 1st b 4 the dist) though the dist does get finalized b 4 mixture
[Re: dweller]
#996857
05/21/11 09:45 PM
05/21/11 09:45 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
It degreed in exactly matching the cam card at 106* ATDC intake centerline. I have a three keyway crank sprocket set.
That will work fine and is 4 degrees advanced as comp recommends.That cam is very small(made for a mild 350cid engine) in a 440 it will not lack for bottom end power.
[Re: goldmember]
#996858
05/21/11 10:11 PM
05/21/11 10:11 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Per the cam card int@106 c/l
Leave the gun.......take the Cannoli's....Mike
[Re: dweller]
#996862
05/22/11 02:23 AM
05/22/11 02:23 AM
goldmember
Gainesville,FL
So the Comp specification of 106* ATDC is already advanced 4*?
Yup, this should be a stump puller. 9.2:1 quench pad KB pistons set at .040 quench clearance with ported 452s (mild porting aimed at low lift flow), thermoquad/performer, 1 3/4" headers, single 3.5" exhaust...
Low lift flow is not a help to low rpm torque. But do not worry you'll never know unless you test it.
