Hemi valve adjustment #996154
05/20/11 12:30 PM
05/20/11 12:30 PM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
The valves are really clacking in my hemi (66 block, Dart Alum heads, stock valve train) I pulled the valve covers last night- at least one is WAY out of whack. I'm curious as to which method I should use to adjust them? 1 cylinder at a time? TDC then 1/2 rotation method? What should I set them at- I had it written down- but can't find it. Any other suggestions? Thanks Moparts-
Re: Hemi valve adjustment [Re: Kirby] #996155
05/20/11 12:41 PM
05/20/11 12:41 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Adjust 1 cylinder at a time. Watch the exhaust, when it starts opening adjust the intake on that cylinder. When the intake is almost closed adjust the exhaust. 1/2 turn is the pre-load.
logan426 Martin
Re: Hemi valve adjustment [Re: MLR426] #996156
05/20/11 12:44 PM
05/20/11 12:44 PM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
Logan- 1/2 turn is the pre-load? please explain. Hopefully see ya at Mopars in the Park- especially if it doesn't rain- lol
Re: Hemi valve adjustment [Re: Kirby] #996157
05/20/11 01:03 PM
05/20/11 01:03 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
NO - A 66 Hemi has solid lifters. There is lash not preload. unless of coarse you have used a later model stock valvetrain that has a hydraulic cam and lifters.
Re: Hemi valve adjustment [Re: GomangoCuda] #996158
05/20/11 01:53 PM
05/20/11 01:53 PM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
Nope- solid lifters and comp cam. Found the sheet .012 intake .014 exhaust.
Re: Hemi valve adjustment [Re: Kirby] #996159
05/20/11 03:48 PM
05/20/11 03:48 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Well that's different you first explained you had a 1/2 turn SO I THOUGHT YOU HAD A HYDRAULIC.
Now use the same procedure and use a feeler gauge to set lash.
logan426
Re: Hemi valve adjustment [Re: GomangoCuda] #996160
05/20/11 03:53 PM
05/20/11 03:53 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
stock valve train has nothing to do with what cam is used.
logan426
Re: Hemi valve adjustment [Re: Kirby] #996161
05/20/11 03:56 PM
05/20/11 03:56 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
I just knew sooner or later you would bring RAIN up.
I will be in the 71 car display in the building, but I'm hoping for no rain as well.
logan426
Re: Hemi valve adjustment [Re: MLR426] #996162
05/20/11 04:12 PM
05/20/11 04:12 PM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
Yeah- I figured you'd like that. Want to line the 71's up?
Re: Hemi valve adjustment [Re: Kirby] #996163
05/20/11 04:25 PM
05/20/11 04:25 PM
Take off dist cap & hand turn the crank till the rotor is lined up w #1 plug and timing marks are at TDC & adj #1 cyl intake valve so a .011" feeler gauge has no drag and a .013" feeler blade has a slight drag then tighten the adjuster and on the ex adj till a .013" has no drag and a .015" has a slight drag then tighten the adjuster. (hand) turn crank till the rotor is at the same (relative) location on #8 plug wire & repeat above & so on around the firing order. If the plugs on a Hemi come out easy it'd sure make it easier to (hand) turn
Re: Hemi valve adjustment [Re: RapidRobert] #996164
05/20/11 04:59 PM
05/20/11 04:59 PM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
Thanks Robert- plugs are out- had to, to pull VC's. As well as a whole lot of other crap- took me 2 hours just to get them off-
Re: Hemi valve adjustment [Re: Kirby] #996165
05/20/11 05:02 PM
05/20/11 05:02 PM
to pull VC's- took me 2 hours just to get them off-
Maybe I dont need a Hemi as bad as I think I do
Re: Hemi valve adjustment [Re: RapidRobert] #996166
05/20/11 05:22 PM
05/20/11 05:22 PM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
Robert- It's a beast when running- but in hind sight- I think I woulda gone w/hydralics. Here's a breakdown of what it took to pull VC's
Passenger- Shaker off, unhook heat control valve from inner, flip it up and out of way, drop pass shock, loosen Motor mount,jack up pass side of motor, loosen heater fan for clearance, plugs out, vc nuts off- unhook some of the wiring harness, barely comes out.
Drivers side, plugs, nuts, unhook brake lines from master, unhook brake pedal, and 4 nuts holding booster. I'm sure I'm not remembering something.
Unfortunately, I'm getting faster at it, and I don't even have my A/C hooked up yet.
Last weekend I took a buddy for a ride- shifted out of 3rd @ 110mph- I wonder what the top end would be? Keisler 5 speed, Dana 60 w 3.23's and 295/45/18 in back. Wild ride!
Re: Hemi valve adjustment [Re: Kirby] #996167
05/20/11 05:24 PM
05/20/11 05:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
With stock valve train the procedure below works well.
Re: Hemi valve adjustment [Re: Kirby] #996168
05/20/11 05:40 PM
05/20/11 05:40 PM
You had me talked out of one till I read the "wild ride" descrip further down
Re: Hemi valve adjustment [Re: RapidRobert] #996169
05/20/11 08:51 PM
05/20/11 08:51 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
I always wanted one but didn't need one. Then my friend gave me a ride in his 68 Hemi GTX and said we aren't getting any younger and no Mopaqr man should go to his grave without owning "KING KONG". Right then and there I decided I needed one. Got one about half built and can't wait to put it in the car.
Re: Hemi valve adjustment [Re: Kirby] #996170
05/26/11 12:42 PM
05/26/11 12:42 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
If I were going to bring my 70 AAR Cuda with the crossram hemi I would take you up on that.
logan426
Re: Hemi valve adjustment [Re: Kirby] #996171
05/26/11 09:21 PM
05/26/11 09:21 PM
badblack68 Offline
badblack68  Offline
Where did you get 3:23's for a dana 60?
