Battery & charging problems? #995302
05/18/11 11:28 PM
05/18/11 11:28 PM
Illinois
Mopar_Ray Offline OP
Illinois
Having a couple of problems, maybe related or 2 different problems? A little about the build... 505 stroker, about 11.5:1 compression. I have a Powermaster 1 wire 75 amp alternator, never goes over 12 volts on the voltmeter? And a Optima yellow top battery 750 amp, have to turn off ignition until cranking and than flip on the ignition to turn it over. Any ideas?
Re: Battery & charging problems? [Re: Mopar_Ray] #995303
05/18/11 11:46 PM
05/18/11 11:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Disconnect the battery cable and measure the voltage
at the battery... connect the cable back on... start
the engine and measure the voltage at the battery again
and see if its higher
Re: Battery & charging problems? [Re: Mopar_Ray] #995304
05/19/11 01:41 AM
05/19/11 01:41 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
From what your describing your Alts not charging and your Bat is discharged to XX amount of volts.
With your engine running you should be able to measure around 14 volts +/-. The bat fully charged should measure 12.75 +
Start with the Alt.
Re: Battery & charging problems? [Re: Mopar_Ray] #995305
05/19/11 06:01 PM
05/19/11 06:01 PM
Penna
70satelliteguy Offline
Penna
Mopar Ray I just went thru this with my car and Powermaster alternator. I have been told that the internal voltage regulator is usually the culprit. Had mine rebuilt but it only lasted a short time so I just ordered a new one from Summit(had to have one quick to be able to race) and will have the old one rebuilt(voltage regulator) again and keep it for a spare.
Mike
Re: Battery & charging problems? [Re: 70satelliteguy] #995306
05/21/11 08:44 PM
05/21/11 08:44 PM
Illinois
Illinois
Thanks, Think I am going to step up to a 140 amp anyway. We''' see what happens.
Re: Battery & charging problems? [Re: Mopar_Ray] #995307
05/21/11 09:01 PM
05/21/11 09:01 PM
NE OHIO
SRT440DUSTER Offline
NE OHIO
IMO it sounds like poor grounds.
