Ok so I spliced my points harness to switch over to electronic ignition.on my 72 duster.... I get power to the coil.. but nothing coming out. I've replaced the coil...ecu ..resistor. and still no spark also noticed no power is getting to the dist. If all is wired right... what am I doing wrong?? Has anyone done this before... the motor ran before I took and swapped it ....it was from a 76 valare
