INSTALLING HEADLINER #994929
05/18/11 02:07 PM
05/18/11 02:07 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
Do you have to pull front & rear glass to do in a e body ???
I do know it would be easier but is it mandatory?
thanks abe
Re: INSTALLING HEADLINER [Re: AB&E] #994930
05/18/11 02:10 PM
05/18/11 02:10 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I would...FWIW if you've never done one (and I have not because of horror stories) You should at least have somebody with you that has.
Coming soon!!!!
Re: INSTALLING HEADLINER [Re: Mr.Yuck] #994931
05/18/11 02:14 PM
05/18/11 02:14 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
No it's not nessesary but it will go alot easier if the glass were out.
Re: INSTALLING HEADLINER [Re: AB&E] #994932
05/18/11 02:19 PM
05/18/11 02:19 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
No, it's not necessary. And it's not the easiest job to do either. We did the one in our Challenger in the winter, using a heater. It would be better to do one in warm weather, lol.
Resto Rick has the best write-up on it:
http://www.restorick.com/tech/topic.asp?TOPIC_ID=7
Re: INSTALLING HEADLINER [Re: dustergirl340] #994933
05/18/11 02:27 PM
05/18/11 02:27 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
well its actually sunny for a few days
I am going to have a shop do it. Its beyond my skills & patience level.
Seems like when I had my 71 340 duster done I HAD to pull glass is this correct
thanks
Re: INSTALLING HEADLINER [Re: AB&E] #994934
05/18/11 07:08 PM
05/18/11 07:08 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
resto ricks tips are great,did mine ,i will add you should put all the screws back in there holes(coat hook,visor,seatbelt,dome)install your headliner,after it will be way easier to feel the head of the screw,then make small slit in head,back out screw,install dome visor ect.it is hard to find a small screw hole,it will also tighten the headliner up more when you install everything else. DOME LIGHT LAST,
