Do 904's and 727's share a cross member? #994889
05/18/11 01:22 PM
05/18/11 01:22 PM
Goodyear Arizona
midnite360 Offline OP
Goodyear Arizona
I am replacing the 904 in my 73 dart with a 727. Will it work with the current cross-member or do I need a differant one? Thanks!
Re: Do 904's and 727's share a cross member? [Re: midnite360] #994890
05/18/11 01:48 PM
05/18/11 01:48 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
The tranny length and rear housings are interchangeable for both transmissions. T
Re: Do 904's and 727's share a cross member? [Re: midnite360] #994891
05/18/11 01:49 PM
05/18/11 01:49 PM
scratchnfotraction Offline
same mount and cross member
only the tail shaft changed in length
727 shorter shaft
904 longer shaft
I even used a 727 short shaft from a truck with a splined drive shaft in my 68 Dart with the 68 904 mount and cross member
Re: Do 904's and 727's share a cross member? [Re: scratchnfotraction] #994892
05/18/11 01:59 PM
05/18/11 01:59 PM
Goodyear Arizona
Goodyear Arizona
Thanks guys! All I needed to know!
Re: Do 904's and 727's share a cross member? [Re: astjp2] #994893
05/18/11 02:42 PM
05/18/11 02:42 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Huh ??? the length from the engine to the trans mount is the same between the 2 , but the tail housing are not interchangeable since the 72 is longer than the 904 and uses a different size yoke .
Re: Do 904's and 727's share a cross member? [Re: astjp2] #994894
05/18/11 02:48 PM
05/18/11 02:48 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I remember the first time I got drunk...........
Re: Do 904's and 727's share a cross member? [Re: Kern Dog] #994895
05/18/11 03:19 PM
05/18/11 03:19 PM
U.S.S.A.
U.S.S.A.
It seems like you haven't stopped ?
Instead of belittling a person maybe it would be more useful of your use on clean air to help educate them ?
Re: Do 904's and 727's share a cross member? [Re: JohnRR] #994896
05/18/11 03:21 PM
05/18/11 03:21 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Clean air????????????????
Take a laxative. YOU have the sense of humor of a mortician.
Re: Do 904's and 727's share a cross member? [Re: JohnRR] #994897
05/18/11 03:41 PM
05/18/11 03:41 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I have personally swapped them, on an AMC, they were exactly the same and the spline for both was a 23. Tim
Re: Do 904's and 727's share a cross member? [Re: astjp2] #994898
05/18/11 04:01 PM
05/18/11 04:01 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Think the original poster wants to know if the 727 needs a different crossmember when the upgrade to 727 from 904 is made. Answer is both trans's use the same crossmember, okay?
Re: Do 904's and 727's share a cross member? [Re: astjp2] #994899
05/18/11 04:17 PM
05/18/11 04:17 PM
U.S.S.A.
U.S.S.A.
Well then take that as an FYI , they are NOT interchangleable on Chrysler spec transmissions.
Re: Do 904's and 727's share a cross member? [Re: buildanother] #994900
05/18/11 05:29 PM
05/18/11 05:29 PM
Goodyear Arizona
Goodyear Arizona
Yup Thanks!
Re: Do 904's and 727's share a cross member? [Re: JohnRR] #994901
05/18/11 05:44 PM
05/18/11 05:44 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Yeah JohnRR...... My comments were WAAAY off.
