Maximum overbore for a 360 block #994825
05/18/11 10:42 AM
05/18/11 10:42 AM
Raleigh N.C
hemiparts Offline OP
"Missile Pilot"
"Missile Pilot"
Raleigh N.C
We smoked our 340 AGAIN !! thinking about going to a 360 block ( alot easier to find ) what is the max overbore that would be safe for a 360 block ??
Re: Maximum overbore for a 360 block [Re: hemiparts] #994826
05/18/11 10:57 AM
05/18/11 10:57 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
No personal experience but according to Herb McCandless, an early 360 used the same same cylinder cores as a 340 so if that is true, .080" to .100". It has to be from the first year of production IIRC so that would be 71? A sonic check would confirm this.
Kevin
Re: Maximum overbore for a 360 block [Re: hemiparts] #994827
05/18/11 10:58 AM
05/18/11 10:58 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
every block is different - especially used ones - Sonic check ( ~ $75) to determine the actual amount you can overbore the block.
