Will Cut Outs Improve my E.T? #994805
05/18/11 09:56 AM
05/18/11 09:56 AM
usa
mrmopardan Offline OP
usa
I make a occasional 1/4 Mi. pass down the track. I race with full 3 " TTI exhaust with their Dynomax mufflers. This exhaust seems to flow well but I'm wondering if there is even more performance to be had through exhaust modifications. would there be an improvement by adding "cut outs"? Anyone tried this and if so where is the ideal location to install and which brand. Thanks, Danny
68 GTX Full street trim, solid lifter cammed. Best 11.34 @ 121 mph. 1.72 60 ft. (yeah I know.. my 60 ft. sucks)
Re: Will Cut Outs Improve my E.T? [Re: mrmopardan] #994806
05/18/11 10:23 AM
05/18/11 10:23 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
un-capped seems to pick up 2-5 tenths depending on system. Since you have a decent 3" I'd guess you'd pick 2 or so. Enought to dip into the 11's I'd think. My old 67 coronet w/ a mild 440 and 2.5 system would drop 3.5 tenths w/ the exhaust open.
And before those guys who get on here and claim no difference.. I don't count a 3.5 with a race mufflers and no tail pipes as an exhaust system.
If you want to see how much, un-cap the headers and make a blast. That way you'll get an idea.
Coming soon!!!!
Re: Will Cut Outs Improve my E.T? [Re: mrmopardan] #994807
05/18/11 10:24 AM
05/18/11 10:24 AM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
I would doubt it would improve enough that you would notice it. I run a full 3 inch exhaust with magnaflows and if I drop the exhaust I don't really notice much improvement. maybe .05 at the most.
Re: Will Cut Outs Improve my E.T? [Re: mrmopardan] #994808
05/18/11 10:34 AM
05/18/11 10:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I am planning a cut out system for my Rampage BUT I
will have a header with about 16" long collector and
I will come off the side of the collector to run to
my exhaust, where most guys run straight off the back
of the collector... you would need to jet differently
without the exhaust... this is where guys dont see
any change due to not jetting for the change... I
plan on a split on the jetting... not perfect for
either set up, unless it will see alot more street
mileage, then I'll jet for the street and the exhaust
Re: Will Cut Outs Improve my E.T? [Re: DodgeCharger] #994809
05/18/11 10:38 AM
05/18/11 10:38 AM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Same question almost a few days ago. Same answer. We found that if you drop the whole exhaust system off the car you will gain .1 to 1.5 in the 1/4. We guess some or most of that gain was for the lost of weight. You are just adding cut outs. Probly all your going to gain is to the noise pollution. Is it worth the hassel? If you have a totally junk exhaust yes if not no.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: Will Cut Outs Improve my E.T? [Re: mrmopardan] #994810
05/18/11 11:21 AM
05/18/11 11:21 AM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
66 belvedere, 431/tti 1 7/8, 3 in (with tailpipes), dynomax, 4sp, cutouts
saw no consistent measureable difference (best 11.07, consistent 11 2s to 3s. Would often run street stick class (closed) and quick stick (open) one after another. Liked the pipes open so I could hear engine revs on shifts (know if clutch slipped), plus I basically like the noise. If anything, slowed down slightly w/cutouts open, ran lean. If carb was jetted properly for open pipes probly would have picked up, but never tried cause I'm basically lazy.
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Will Cut Outs Improve my E.T? [Re: oldiron] #994811
05/18/11 03:01 PM
05/18/11 03:01 PM
usa
usa
As I continue to research this subject.. I also have the oval GTX exhaust tips too. Are they restrictive??
Re: Will Cut Outs Improve my E.T? [Re: MR_P_BODY] #994812
05/18/11 03:23 PM
05/18/11 03:23 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
amen to that! I've picked up 3-4 tenths with open exhaust AND jetting. I once forgot to re-jet when I uncapped and saw no gain, and ran very lean to boot.
Re: Will Cut Outs Improve my E.T? [Re: dustergirl340] #994813
05/18/11 03:35 PM
05/18/11 03:35 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I have seen guys switch to a more free flowing exhaust and have a slower E.T. and had it run leaner. So there is a lot to just dumping the pipes and goin racing.
Kasey
Re: Will Cut Outs Improve my E.T? [Re: Moparnut426] #994814
05/18/11 05:01 PM
05/18/11 05:01 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I ran an X-pipe on my old car with Magnaflows and turnouts in front of the rear tires, it was pretty quiet and ran 9.90 with or w/o the exhaust system.
Re: Will Cut Outs Improve my E.T? [Re: ProSport] #994815
05/18/11 05:12 PM
05/18/11 05:12 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
68LAR went from a 11.60 to a 11.28 just with opening the exahust. No jetting change. He has a full 3" sysytem with dynomax ultraflows.
Re: Will Cut Outs Improve my E.T? [Re: Jeff_383] #994816
05/18/11 05:24 PM
05/18/11 05:24 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think I was the winner of the "how much faster" contest on that one.
Re: Will Cut Outs Improve my E.T? [Re: DodgeCharger] #994817
05/18/11 07:47 PM
05/18/11 07:47 PM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
Same deal - Magnaflows with twin 2.5" and X pipe.
I have electric cuot outs, I open them at the track and tune one stage richer and no difference.
If I don't tune one stage richer it leans and I go slower.
Thats the benefit of maganflows - they actually flow.
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Will Cut Outs Improve my E.T? [Re: mrmopardan] #994818
05/18/11 08:18 PM
05/18/11 08:18 PM
Locomotion Offline
Locomotion  Offline
A lot depends on how the carb is jetted. Typically, ideal jetting for a closed exhaust will be lean for an open exhaust. Of course, the more cubes and rpm's you have, will also be a factor, so the results depend on how efficient the exhaust is compared to the amounbt of air/fuel you're putting through it.
I've been running TTI step headers on my 360 for years and had the carb tuned for it as best as I could. A few years ago I installed a 3" x-pipe and Dynomax Ultra Flo mufflers (oval) ending at the rear end housing. After some carb tuning which I believe included dropping the jet sizes 1-2 numbers and getting the weight back to what it was (system was +60 lbs), the car was about .5-.10 faster than open headers! I can only assume that the x-pipe affected the jetting, overall helped my particular combination and that the mufflers were not a restriction.
Re: Will Cut Outs Improve my E.T? [Re: MR_P_BODY] #994819
05/18/11 09:18 PM
05/18/11 09:18 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Will Cut Outs Improve my E.T? [Re: slippery440] #994820
05/18/11 10:32 PM
05/18/11 10:32 PM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
Re: Will Cut Outs Improve my E.T? [Re: Mr.Yuck] #994821
05/18/11 10:39 PM
05/18/11 10:39 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
My car picks up about .2 with them open. And I agree that testing with the exhaust open at the track will tell you what you need to know.
Because there is a car show most weekends around here, I hit a couple a month. Which means the car sees more show time than track time. The cut-outs are more fun at car shows than they are at the track. I have cops come by and ask me to open them up and fire it up.
Cut-outs are just tons of fun on the street! The added performance at the track is gravy.
Master, again and still
Re: Will Cut Outs Improve my E.T? [Re: DaveRS23] #994822
05/19/11 02:04 AM
05/19/11 02:04 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
When I bought my car it had a fairly new exhaust sytem with Flowmasters on it, but it was 2-1/4" pipe. So I added about 18" of 3" pipe off the headers (to get past the subframe) leading to a set of 3" cutouts, then it steps down to 18" of 2-1/2, and then down to the existing 2-1/4" setup. I see a solid .25 when open, but my system is relatively restrictive compared to a full 3" system.
To make it pay, you really need to rejet
