Lower radiator bung interference in '63 330. #994610
05/17/11 11:32 PM
05/17/11 11:32 PM
Anonymous OP
Anonymous OP
I put a smallblock 22" radiator in my '63 330 with the bigblock. I thought the radiators were the same except for the upper outlet which I have handled with no problem?!
Do I need to shorten the bung on the radiator or get a shorter oil filter?
How was the BB radiator lower bung arranged?
Pic of the dilemma:
Re: Lower radiator bung interference in '63 330. #994611
05/18/11 12:04 AM
05/18/11 12:04 AM
do some quick measureing/eyeballing & if a shorter filter would give you room to run the hose that'd b the fastest solution. BB's did come w the hose on both sides so not sure how that worked as I'm just getting back into BB's. Might b when they switched the hose they switched the nipple. holler how it turns out & the sol
Re: Lower radiator bung interference in '63 330. [Re: RapidRobert] #994612
05/18/11 01:25 AM
05/18/11 01:25 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
A radiator shop can sweat the bung out and either angle it to the car's left, or replace it with a bung that will.
Re: Lower radiator bung interference in '63 330. #994613
05/18/11 06:56 AM
05/18/11 06:56 AM
Minn
SportF Offline
SportF  Offline
Minn
A big block radiator had the outlet all the way over which would give you another couple of inches. That is a particularly long stub on your radiator. If you shorten that you can get a hose on that as I have done that a couple of times, but it is always a fight with the filter when changing oil. But you can do that. Also as said, a radiator shop can move that as well. Good luck, that year Dodge is a great looking car.
Re: Lower radiator bung interference in '63 330. [Re: SportF] #994614
05/18/11 09:33 AM
05/18/11 09:33 AM
SportF nailed it
Re: Lower radiator bung interference in '63 330. #994615
05/18/11 09:38 AM
05/18/11 09:38 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
gy-guy NAILED IT his-self ..
. the Mopar 3.3/3.8 V-6 oil filter is a shortie that will fit fine.
Re: Lower radiator bung interference in '63 330. [Re: dOrk !] #994616
05/18/11 12:11 PM
05/18/11 12:11 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And with the correct big block radiator.
Re: Lower radiator bung interference in '63 330. [Re: 62maxwgn] #994617
05/18/11 04:53 PM
05/18/11 04:53 PM
Anonymous OP
Anonymous OP
Thanks! That pic helps a lot!
