How well would this Purple Shaft work with my setup? #994534
05/17/11 09:30 PM
05/17/11 09:30 PM
Glendale, AZ
69L78Nova Offline OP
Banned. Forever.
Banned. Forever.
Glendale, AZ
I picked up a MP cam, part number P4452761, from a friend of mine. I was toying with the idea of sliding it into the 360 in my 78 Fury since the XE256 that was in there decided to have a few collapsed lifters one day. The 360 is a stock 78 E58 with the addition of Magnum heads, a dual plane M1, and a 600 Carterbrock. Im running Hooker Comp headers into 2.5" duals with an h-pipe, 3.55 SG and an A518. Would this cam be ok in a heavy car with a 2000 stall? Im not looking for a lopey idle or to be a complete dog down low and get 12mpg. I understand the 78 had soup dish pistons and were a mile down in the hole, but the XE256 ran strong until I pulled it. I posted the specs below. Im thinking there might be too much duration at .050" Should I go for something smaller? Anyone?
Basic Operating RPM Range 1,500-5,800
Intake Duration at 050 inch Lift 228
Exhaust Duration at 050 inch Lift 231
Duration at 050 inch Lift 228 int./231 exh.
Advertised Intake Duration 268
Advertised Exhaust Duration 272
Advertised Duration 268 int./272 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.450 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.455 in.
Valve Lift with Factory Rocker Arm Ratio 0.450 int./0.455 exh.
Lobe Separation (degrees) 110
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: How well would this Purple Shaft work with my setup? [Re: 69L78Nova] #994535
05/17/11 11:51 PM
05/17/11 11:51 PM
Not a cam guy so this is more of a BTT for you but I would consider a cam that will build some psi w as you know those soup dish pistons but you do have the cam in hand & using what's avail is always (within reason) a good plan
Re: How well would this Purple Shaft work with my setup? [Re: RapidRobert] #994536
05/18/11 12:01 AM
05/18/11 12:01 AM
IN
ahy Offline
ahy  Offline
IN
I think 230+ duration @ .050 would not make you happy with your combo. I'd look for something around 210 or max 220 @ .050.
Re: How well would this Purple Shaft work with my setup? [Re: 69L78Nova] #994537
05/18/11 12:07 AM
05/18/11 12:07 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I used that same cam in a stock 78 360 build a few years back.Mine was in a mini motorhome and I pulled about 10,000 pounds of trailer with it.
It did great,idled with a real slight lope and pulled pretty strong.I had headers with dual 2 1/2" exhaust an MP dual plane intake and a 770 Holley Street Avenger on it.
I always thought it would have made a real nice,mild daily driver engine.
Keith
Re: How well would this Purple Shaft work with my setup? [Re: Dunnuck Racing] #994538
05/18/11 12:28 AM
05/18/11 12:28 AM
California
court9155 Offline
court9155  Offline
California
of topic but where did you find the part number on the cam? I cant find a part number on mine. Had to measure a lobe.
Dan
67 charger
Re: How well would this Purple Shaft work with my setup? [Re: court9155] #994539
05/18/11 07:26 AM
05/18/11 07:26 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
We used that same cam in my son's Swinger with a low compression 360, you should really like it. It's just a touch warmer than the 340 mag cam. Dave
Re: How well would this Purple Shaft work with my setup? [Re: quickd100] #994540
05/18/11 12:38 PM
05/18/11 12:38 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
That's good info, but I'm running Magnum heads which have 1.6 rockers. Not sure how that would affect anything. Like I said, I don't want to lose any low and torque.
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
