I picked up a MP cam, part number P4452761, from a friend of mine. I was toying with the idea of sliding it into the 360 in my 78 Fury since the XE256 that was in there decided to have a few collapsed lifters one day. The 360 is a stock 78 E58 with the addition of Magnum heads, a dual plane M1, and a 600 Carterbrock. Im running Hooker Comp headers into 2.5" duals with an h-pipe, 3.55 SG and an A518. Would this cam be ok in a heavy car with a 2000 stall? Im not looking for a lopey idle or to be a complete dog down low and get 12mpg. I understand the 78 had soup dish pistons and were a mile down in the hole, but the XE256 ran strong until I pulled it. I posted the specs below. Im thinking there might be too much duration at .050" Should I go for something smaller? Anyone?
Basic Operating RPM Range 1,500-5,800
Intake Duration at 050 inch Lift 228
Exhaust Duration at 050 inch Lift 231
Duration at 050 inch Lift 228 int./231 exh.
Advertised Intake Duration 268
Advertised Exhaust Duration 272
Advertised Duration 268 int./272 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.450 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.455 in.
Valve Lift with Factory Rocker Arm Ratio 0.450 int./0.455 exh.
Lobe Separation (degrees) 110
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
