Re: Small Block Lean Burn distributor?
[Re: domingo]
#994197
05/17/11 02:49 PM
05/17/11 02:49 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
lean burns, at least the 80's incarnation on M bodies, don't have mechanical or vacuum advance in them...
[Re: patrick]
#994198
05/17/11 05:07 PM
05/17/11 05:07 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
Yep, those are both LeanBurn units with a VR sensor for electronic ignition. The 2nd one has 2 VR sensors in it. I have heard conflicting info that: the dual units were used in copcar applications, or in the later LeanBurn applications that also had fuel control via a feedback carb. (In those apps 1 sensor was used durign starting, teh 2nd one for after hte engine was running). Or either statement could be true.
[Re: domingo]
#994201
05/17/11 09:18 PM
05/17/11 09:18 PM
RapidRobert
How do you spot them?
no vac adv pod EDIT 2 pairs of leads for the dual pickup ones
[Re: FuryUs]
#994202
05/18/11 09:20 AM
05/18/11 09:20 AM
Fury Fan
Indiana
No mechanical or vacuum advance is the clue.
And make sure the vacuum pot hasn't simply been removed, in which case the dizzy will have an open slot where the pot mounted.
[Re: domingo]
#994204
05/28/11 12:50 PM
05/28/11 12:50 PM
RapidRobert
Pretty sure you could use either in a perf app & for sure the single pickup one. You'd just ignore the dual pickup & open it's gap to get it out of the way then gap the other one to .006-.008" at the tightest tooth. Finalize your initial then use that figure to shorten the slots to get 35 total (vac adv unhooked if you are going to add the pod to the dist). You would want to toss the heavy spring w the long loop & sub in another which will take some experimentation to get the right curve then hookup the vac adv & work w it. If the pickups ain't exactly opposite pick the one that will give you the best rotor phasing (location)
[Re: RapidRobert]
#994205
05/28/11 01:11 PM
05/28/11 01:11 PM
Posts: 3,504 DFW
mr_340
DFW
From what I remember reading about that system, one pickup was for START and one was RUN. I don't remember the difference in timing between them. I've thought about trying to use one with an MSD with locked timing and put a switch to toggle between START and RUN. Not too sure if it would work. One of those backburner projects.
Floyd Lippencott IV
