rear 1/4 panel tire clearance-how much is cosidered ok
#994056
05/17/11 12:42 AM
05/17/11 12:42 AM
Posts: 903 Oregon
rtplumcrazy1
i was wondering how much tire to 1/4 panel lip clearance is considered enough at rest---so there would be no rubbing when cornering and what not. I won't tell you that the car i am concerned about is not a Mopar.
Put a big block 4 speed Scat Pack Dodge in your garage.
Re: rear 1/4 panel tire clearance-how much is cosidered ok
[Re: rtplumcrazy1]
#994057
05/17/11 12:45 AM
05/17/11 12:45 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
What type of tires are you running ? An old style tall sidewall 15" tire will flex alot more and probably need more clearance than a modern low profile 17" or 18" setup ? I usually just shoot for having room to fit my fingers in between the tire and quarter and go from there. (3/4" or so?)
[Re: MileHighDart]
#994060
05/17/11 01:34 AM
05/17/11 01:34 AM
Posts: 18,157 Mass
DAYCLONA
Mass
this might sound like a dumb question, but when your cornering and the tires are flexing, isn't all the flexing going on where the tire meets the road, not at the top where the tire is near the fender ?
Anyway, I like to have at least 1/2" or a fingers thickness.
I guess we'd like to think so,...but I have 275/60/15 (rear) GoodYear Eagle GT II's on my Challenger T/A, about a good finger's width between the chrome wheel lip and the tire's face, yet I still get the tire's skin finely cut around it's outer diameter by the edge of the chrome mldgs
[Re: MileHighDart]
#994061
05/17/11 04:23 AM
05/17/11 04:23 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Not dumb at all. Look at video of cars cornering. Most of the flex does occur in the tread area, but depending on the sidewall height, that flex can be transmitted further up the tire. In theory, a 78 series tire may flex halfway up the rim compared to a 40 series tire.
[Re: Kern Dog]
#994062
05/17/11 08:08 AM
05/17/11 08:08 AM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
There is also the issue of how much lateral flex is in the suspension. Stock or old leaves are going to have more side to side movement than heavier new springs.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
